How does a B7800 hour meter work?
   / How does a B7800 hour meter work? #1
Muleskinner
Pioneertown, So CA
2015 KUBOTA B2650ROPS
Does the hour meter start when the engine is running or does the tractor need to be driven to make it register? I did a job that took me four hours today, but the hour meter only registered three hours.
   / How does a B7800 hour meter work? #2
On most CUT's the hour meter reads hour for hour at PTO speed. In other words.......whatever RPM you need to get 540 RPM PTO.
I think /forums/images/graemlins/confused.gif
   / How does a B7800 hour meter work? #3
I think that might be an electric one but not sure. That will add an hour per hour that the key is on.
   / How does a B7800 hour meter work? #4
Muleskinner
Unless <font color="orange"> Kubota </font> changed how the B7800 works from the B2910. The hour meter keeps time by the hours run at PTO speed. If you ran your engine at less than 2600 RPM’s then the full 4 hours will not show on the hour meter.
How are we supposed to keep an accurate count of the actual hours on the tractor if the hour meter only works at full throttle??????????????? I usually run mine around 2000 RPM for most grading work. /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif
   / How does a B7800 hour meter work? #6
The majority of tractors have been using this type hour meter for years.
My new Kioti uses this type hour meter as does my 26 year old John Deere.
   / How does a B7800 hour meter work? #7
<font color="blue"> How are we supposed to keep an accurate count of the actual hours on the tractor if the hour meter only works at full throttle??????????????? </font>
That’s the same way the Hour Meter worked on my 1958 Farmal 340..
   / How does a B7800 hour meter work? #8
</font><font color="blue" class="small">( How are we supposed to keep an accurate count of the actual hours on the tractor...)</font>
I think of it as kinda like an engine odometer. That is, rather than just total running hours, it more closely approximates the total number of revolutions or the total distance the pistons have traveled. In that respect, IMHO, I think it's better this way since it's used to dictate when to change the engine oil.
JMZ
   / How does a B7800 hour meter work? #9
I've wondered how the hourmeter worked since I bought the tractor. Let me make sure I understand, if my PTO speed is 2600 rpm, then if I run the tractor at 1300 rpm, it takes 2 hours running time to record 1 hour on the meter?
   / How does a B7800 hour meter work? #10
<font color="blue"> I think of it as kinda like an engine odometer. </font>
JMZ...I think you are right on there!
<font color="blue"> Let me make sure I understand, if my PTO speed is 2600 rpm, then if I run the tractor at 1300 rpm, it takes 2 hours running time to record 1 hour on the meter?
</font>
8561,
That is exactly the way my B2910 works... /forums/images/graemlins/smile.gif
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
Payment Instructions (A47384)
Payment...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
