How do you store you logging/tow chain?
   / How do you store you logging/tow chain? #301
When I got your reply, I checked in my paper work and found that I had bought in 1998, so it would be 17 years old. What happens is when I pull the cable out, sometimes it will pull itself back in without me pulling on the rope. Will check the clutch before starting to my wood this winter.
   / How do you store you logging/tow chain? #302
Good idea on the clutch check. On mine when the clutch is adjusted right the pulley lever that the rope moves should go up 1-1/2" before the drum starts to turn. Yours is 4 years older than mine.
gg
   / How do you store you logging/tow chain? #303
My Fransgard winch has a spring loaded brake pad under the winch drum, keeps a slight pressure on it so the cable wont self re-wind.
   / How do you store you logging/tow chain? #304
I'm kinda low tech.... I take my 25' of chain and simply heave it into the cab of the backhoe. It resides in the 'drivers side' rear corner. While working forward, it's out of my way, behind me. When I'm turned around using the hoe, I step on it.
This way it's always with the machine if/when I need it.
   / How do you store you logging/tow chain? #305
I'm kinda low tech.... I take my 25' of chain and simply heave it into the cab of the backhoe. It resides in the 'drivers side' rear corner. While working forward, it's out of my way, behind me. When I'm turned around using the hoe, I step on it. This way it's always with the machine if/when I need it.
Same here.
Terry
   / How do you store you logging/tow chain? #306
I removed the passenger side step and replaced it with a tool box.
I removed the passenger side step and replaced it with a tool box. <img src="http://www.tractorbynet.com/forums/files/customization/449605-how-do-you-store-you-imag0978-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/449606-how-do-you-store-you-imag0979-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/449607-how-do-you-store-you-imag0980-jpg"/>
nice!
nice!
   / How do you store you logging/tow chain? #309
I used to carry them in the FEL when I thought I would need them. Now I keep them in various parts of our 90 acres - some under dirt, some under leaves - some have been stored that way for years. I estimate I have about 6 chains stored this way. Not very convenient though when you need one and cannot remember where it got dumped out of the FEL. So, now I think I will build one along the lines of the 4 to 6 inch PVC suggestions. It will be less expensive.
   / How do you store you logging/tow chain? #310
I'm able to hang a couple of chains on the left FEL fork. I carry a choker chain on the backhoe when it's mounted.
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
