How do you skid logs with your tractor..pics?
   / How do you skid logs with your tractor..pics? #41
Take a look at my pics in the iseki forum. The rear hitch and skidding chains are very handy. I have a 2 inch square piece of heavy wall steel, and attached to it with a clevis are two short 3/8ths chains with clevis hooks on the end and swivels in between. For skidding chains I use two 3/8th's tow chains with a loggers slipper link on one end and a hook on the other. The slipper links have an opening that you twist the chain through, and then it tightens like a choker collar on a dog, and the log dosn't slip. Sounds harder than it is. Works great. Using the longer rear 2 inch bar lets me raise the butt of the log when I need to for skidding.
   / How do you skid logs with your tractor..pics? #42
   / How do you skid logs with your tractor..pics? #43
I hooked the logs in the pics the way johnk did. It is a pain to get a chain under some of the big logs. I have tongs from Northern Hyd. now. That will make hooking up a lot quicker.:D
   / How do you skid logs with your tractor..pics? #44
   / How do you skid logs with your tractor..pics? #45
   / How do you skid logs with your tractor..pics? #46
PaulChristenson said:
Paul Buffalo Biography -- Tim Roufs -- University of Minnesota Duluth
Check out the pictures towards the end of the article...And you'll see REAL HP...:D
The Horses PULLING those HUGE PILES are how may Grandfather funded his farm in North Dakota by logging in Minnesota each winter...:D
I showed that link to my wife last night. She home schools our 9 year old daughter. She spent most of today on the link as a home school assignment...said they both loved it.:D
   / How do you skid logs with your tractor..pics? #47
   / How do you skid logs with your tractor..pics? #50
I kind of cheat . I use a 350 B to pull logs in . Just use chains get off and hook up. pull logs to spliter . The first picture is of set up to split wood . The second is picture of hole set up and housing for two weeks on farm to get in fire wood for winter . The third is the results, a winters supply of fire wood the stack is 40' long 5' high two deep with about 16' in third row for fireplace.
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV4NPNJ0430, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2010 FORD F-150 (A58214)
2010 FORD F-150...
NEW Fork Extensions (A59000)
NEW Fork...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
