How do you remove these fasteners?
/ How do you remove these fasteners? #11
I just put mudflaps on our Suburban. Had to do the same thing. I was able to get all of them out by just putting a medium flat screw driver under the center and prying out. That usually pulled both pieces out. Incidentally, if you are installing GM mudflaps (I did), you won't have to reuse those. The flaps themselves inlcude the body clips and the additional bolts needed to do the install.
/ How do you remove these fasteners? #12
Or you can just pry on it till it breaks and then try and find a replacement that will work afterward.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2014 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2014 FORD F-250 XL...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
