How do you remove a plastic handle?
/ How do you remove a plastic handle? #1
yoyo
NC
Kioti CK25HST
I have a CK25HST and the shroud surrounding the 3-pt height adjustment lever broke where the little stop adjustment was. I ordered the shroud and I am ready to replace it but the problem is that the plastic handle on the lever needs to be removed. It appears to have been pressed on while hot. How do you remove this handle?
/ How do you remove a plastic handle? #2
You should be able to just pull it up and off.
/ How do you remove a plastic handle? #3
It pulls off, but you may need to break the vacuum under it as it pulls off. Either work a thin screwdriver or similar up along one side to allow air in as it comes up or drill a pin hole in the top so air can enter.
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
Gannon 12in. Bucket with Teeth Excavator Attachment (A64194)
Gannon 12in...
2008 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2008 Dodge Ram...
2022 EZ-GO ELITE...
