How do you remove a plastic handle?
   / How do you remove a plastic handle? #1
yoyo
Bronze Member
NC
Kioti CK25HST
I have a CK25HST and the shroud surrounding the 3-pt height adjustment lever broke where the little stop adjustment was. I ordered the shroud and I am ready to replace it but the problem is that the plastic handle on the lever needs to be removed. It appears to have been pressed on while hot. How do you remove this handle?
   / How do you remove a plastic handle? #2
You should be able to just pull it up and off.
   / How do you remove a plastic handle? #3
It pulls off, but you may need to break the vacuum under it as it pulls off. Either work a thin screwdriver or similar up along one side to allow air in as it comes up or drill a pin hole in the top so air can enter.
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
T3 Motion Patroller Segway (A51694)
T3 Motion...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2012 WESTERN STAR 4900 SB (A52472)
2012 WESTERN STAR...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
