How do you open canning jars?
/ How do you open canning jars? #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
We've had a really good year in the garden this year, and my wife has gone crazy canning stuff. Her salsa is AMAZING!!! But now I'm struggling to open the jars.
I had a plastic handled thing that was OK, not great, at getting them lids open, but I broke it last night. Today I really struggled to get the lid off of a jar of salsa for my eggs, and I need to find something that will do this for me.
What do you use? Or even better, what could I buy for my wife to use so I'm not the jar opening guy?
After reading your replies, I'm editing this to clarify that it's the ring that I'm struggling to remove. Some are easy, others take some effort and a few feel like they are welded on.
/ How do you open canning jars? #2
I assume you mean the ring, right, not the lid... ?
We remove our rings after the jar has sealed....wife washes the jars them and puts them up....then washes the rings for another run. If we get one that won't come off (most do....the longer the are on the jar, the worse they set up...like glue), we simply run it under hot water for a short time....and if that doesn't do it (rare), tap the ring with the back side of a case knife in 3-4 places....that always works.
/ How do you open canning jars? #3
Maybe this will help:
JAR OPENER BUYING GUIDE: how to choose jar opener that works • Jar and Can Openers % %
/ How do you open canning jars? #4
Case knife? That brings back a lot of memories...but I haven't heard a table knife called a Case knife in 60 years! My Mom always referred to it as a "Case knife".
/ How do you open canning jars? #5
Bottle opener breaks the seal.
/ How do you open canning jars? #6
My wife, Arnold, also removes the rings easily after they are sealed and reuses the rings for the next patch. Worked that way for 40 years. :D
/ How do you open canning jars? #7
We remive the ring after they seal and cool down, then simple opener to pop the lid. We also make salsa, yummmm.
If the ring is a problem, i would think oil filter plyers would work great.
/ How do you open canning jars? #8
Well, we're kinda ole fashioned here....... :D
/ How do you open canning jars? #9
If you mean the ring - run under hot water. If you mean the lid - a "church key". Be gentle with the church key and don't deform the lid.
If you are a brute and DO deform the lid & seal - two layers of Suran Wrap and the ring.
/ How do you open canning jars? #10
Maybe it's self defeating but my wife cans a bunch and we leave the sealing rings on. When it comes time to open a jar of say spaghetti sauce or pickled beets or Kraut (we make a lot of kraut here, I do the work on that), I take a pair of needle nose pliers and grip the rolled edge of the sealing ring and wind the pliers up (just like an old ham can key) from the bottom of the ring to the top and that removes the ring from the jar and then I use an old school can opener to remove the lid. Wife is very particular about her jars and she has many very old blue glass Ball jars.
Works every time and I've never broken a jar. Sealing rings and lids are cheap anyway. Wife buys them in boxes of 50 each.
/ How do you open canning jars? #12
More Wheaties for breakfast. Build up your strength!
A couple of strap wrenches should work. Easiest is to pry up one side of the screw on rim to break the vacuum seal with whatever is handy. Fork handle, knife tip, fork teeth etc.
We have a lot of kitchen knives with the point bent or broke off!:ashamed:
/ How do you open canning jars? #13
I do a lot of canning and after the jars have cooled off and the lids set, I make sure the bands are loose, but I leave them on the jars. You don't want to set the ring down hard before you run it through the canning process, so it can vent, but if a ring is too stubborn to loosen after the jars are cool, the back side of a kitchen knife has always done the trick for me.
/ How do you open canning jars? #15
Oil filter removal/install tool. :)
/ How do you open canning jars? #16
My compliments!
And mine. :) ("I've seen your work." ;))
Arthritis limits my grip strength. Those 'grippers' let me apply the muscle, and they clean so easily to maintain their tack. :thumbsup:
Mom tapped tight lids firmly against a counter edge, never left a dent that I noticed, always works for me.
Under warm water the lid should expand more than the glass, so tapping with anything need not be as energetic.
Store-bought lids will never 'stick' like old galvanized or tin Ball-type rings where we've canned. (We go thru' more lids.)
The under-cabinets openers pretty much demand a two handed grip. Reviews are obviously biased toward .. how well they work. :D
btw, add grip to clean strap wrenches & lids with a pinch of powdered rosin, or single wrap of double-stick tape. ..
/ How do you open canning jars? #19
I've had good luck tipping jar upside down than couple 2 finger stern taps than lid right side up cloth with nubs follow with firm grip remove the lid.
/ How do you open canning jars? #20
You guys actually destroy lids/rings...!?
On purpose!?
Not around here. And not when I was growing up. That would have (and will) get you killed dead.
I've rapped them (as in tapped them) against the corner of the kitchen counter, and used the under cabinet "gripper" thing if that didn't work.
Worst I've had to do is run the top of one under hot water for a few minutes and do the tapping on counter thing and "gripper" thing again.
But destroying one... bbrrrrr... that sent shivers down my spine. I can feel the cold, clammy hand of Death Himself reaching for me just thinking about it.
Woods 3pt 5' Mower (A64912)
Woods 3pt 5' Mower...
2010 CHEVROLET TAHOE SUV (A66091)
2010 CHEVROLET...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2020 JOHN DEERE 325G SKID STEER (A65056)
2020 JOHN DEERE...
2018 Bobcat MT85 (A64911)
2018 Bobcat MT85...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
