How do you like your RTV500
   / How do you like your RTV500 #11
I have owned a Kawasaki Mule 610 since May 2005 (when they started selling 'em) and have almost 500 hours on it. Other than routine maintenance I haven't touched it. No problems.
Zip Zero Nada!
It fits in the back of my truck and has worked it's butt off here on my farm. Its saved excessive wear and tear on my knees and back. Plus the wife luvs to drive it. (Honey while your up at the barn hows about mucking out those stalls). <G>
It doesn't go 55 but with the narrow trails and steep hills 'round here
it doesn't need to.
Gas powered - Air cooled - belt drive. Sometimes simple is better.
jd
   / How do you like your RTV500 #12
lET ME KNOW HOW THE PLOW PERFORMS. dOES IT HAVE A FLOAT POSITION?
Has anyone else put a plow on the 500?...The cutting bar seems to be too big, about 5 inches high. I cant find anything to put on the bottom of the plow to prevent moving gravel around. i used a machine belt on my quad and that worked. This has a 2" reveal from the bottom of the plow to the bottom of the bar..Any rubber will just fold under. I really dont want to cut the bar down...Any suggestions?
   / How do you like your RTV500 #13
Someone mentioned in other posts about taking a piece of 3" sched 40 PVC, cut it to the width of the blade, then put a slice in it and slide it onto the blade. It will push snow and not dig into the gravel.
I plan to try this on my backblade?????????? one of these days????????????
(didn't do it 2007, 2008 maybe this year!!!!!!)
jw5875
   / How do you like your RTV500 #14
jw5875
That's an idea...Thanks
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
