How Do You Hook Up Your Gooseneck?
   / How Do You Hook Up Your Gooseneck? #11
I bought a conversion and use my 5th wheel hitch and it's much easier to line up and hook up.
   / How Do You Hook Up Your Gooseneck? #12
No idea why a GN need them and a fifth doesn't but I found out the hard way. I guess a fifth wheel is supposed to be a more secure connection.
   / How Do You Hook Up Your Gooseneck? #13
Fifth wheel hitch with King pin trailer connector does not require chains, think semi truck and trailer. Any trailer attached to the tow vehicle with BALL requires chains whether it is a tag pull or bumper pull. Would you just say screw the safety chains with a bumper pull trailer? A goose neck trailer attached to the truck with a ball still needs chains even though the ball is over the axle.
If you haul commercially the DOT will place your vehicle Out of Service if the safety chains are not connected if a ball pulls your trailer. All you would need to do to fix the Out of Service Order is hook up the chains but you would be left with a hefty fine of up to 2k for driving a truck that was placed Out of Service.
Personally I hook up the safety chains. If your trailer becomes detached and there is evidence that the chins were not hooked up and you hurt somebody jail time is a real possibility.
   / How Do You Hook Up Your Gooseneck? #14
I do not know if there are any scientific reasons why chains are required with Ball pull VS king pin pull but I do know there are regulatory DOT reasons.
   / How Do You Hook Up Your Gooseneck? #15
Rules must have changed somewhere along the line, I bought a 1993 Gooseneck brand stock trailer brand new and it has never had any safety chains, I would have never thought that a big manufacturer like Gooseneck would have sold a trailer that was not DOT compliant, I don't know that any of the deckover or stock trailers from that era had safety chains, maybe someone else that has an older trailer can chime in.
   / How Do You Hook Up Your Gooseneck? #16
When I got my ticket was in 98 or so. I was hauling a factory made trailer made in the early nineties that had no safety chains. It must have changed somewhere in that time frame. Come to think of it the dealer installed the gooseneck hitch in the truck also and it didn't have provisions for the safety chains.
   / How Do You Hook Up Your Gooseneck? #17
I just looked at the Gooseneck trailer site gooseneck.net and every photo of their trailers shows chains hanging from them. Dollars to doughnuts your trailer has attachment points for safety chains in the neck of trailer near the down tube, just no,chains hooked up.
   / How Do You Hook Up Your Gooseneck? #18
After getting out to look at the ball about 3 times to get it lined up I lower the trailer on the ball and then climb in the back of the truck to latch it and hook up the safety chains. I'd way rather have have a GN over a 5th wheel. The 5th wheel was easier to hook up, but the hitch was way more trouble to put in the truck. I'm not one of the people the only haul air in my truck so I had to remove the hitch almost every time I finished using it. Not to mention the hitch I had cost $1000 and took up space in the garage when not in use. I'll never have another 5th wheel. If I ever have another camper I'll put a GN converter on it.
   / How Do You Hook Up Your Gooseneck? #19
"Would you just say screw the safety chains with a bumper pull trailer? A goose neck trailer attached to the truck with a ball still needs chains even though the ball is over the axle."
Whatever. I have two gooseneck trailers. Neither one was required to have chains when it was manufactured. Both inspected without chains. I worked at a dealership that had half a dozen gooseneck trailers. No chains.
New normal I guess. Like driving a million miles without a seat belt. I'll look into it. Never been DOT'ed. I would hate to make a bad 1st impression...
   / How Do You Hook Up Your Gooseneck? #20
"Would you just say screw the safety chains with a bumper pull trailer? A goose neck trailer attached to the truck with a ball still needs chains even though the ball is over the axle." Whatever. I have two gooseneck trailers. Neither one was required to have chains when it was manufactured. Both inspected without chains. I worked at a dealership that had half a dozen gooseneck trailers. No chains. New normal I guess. Like driving a million miles without a seat belt. I'll look into it. Never been DOT'ed. I would hate to make a bad 1st impression...
That is the issue, DOT officers interpret regulations to fit their fancy
Brush cutter (A55973)
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55852)
2021 Delta...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2018 Ford F-550 Versalift Stamm ATR45N 40ft Bucket Truck (A55852)
2018 Ford F-550...
2013 Ford F-150 (A53422)
2013 Ford F-150...
