How Do You Guys Coax Big Rocks Into Your Bucket????
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #31
Let's see...
There's the pick it up with the grapple method which works good for one at a time like large rocks. But slow for a bunch of smaller ones. IMG_0408.JPG
I've tried using a 3 point scoop bucket and backing under them.
I've drug them with a chain. This will make the missus mad when done across her yard!
Currently working on a solution with a wizard with a magic stick name of Harry Potter that says he can take care of them. Just have to finish scraping up the rest of the deposit!
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #32
Moss - I think the reason everybody is recommending a grapple or even pallet forks is because there is no "secret method" of cokesing a rock into a bucket. Some times you can get under it and it will fall back into the bucket. Most times, you are out there using brute force to leverage it into the bucket.
Lord knows - its apparent a lot of us have tried.
I guess I don't understand why its so difficult. If the rock can fit in my bucket, I can get it in the bucket by just scooping under it and curling the bucket back, then lifting. If its too large, when I curl back, it falls out over the leading edge. If its too heavy, the rear tires lift off the ground. Maybe its something to do with the design of the loaders on most tractors? Mine's a tad different.
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #33
Oh, and I have pallet forks, too, which I use for stuff that won't fit in the bucket, but I left those out since the topic was buckets.
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #36
A big buddy could rest his foot on it to prevent it from sliding.
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #37
If you have both rocks and snow you should have two tractors. One with a snowplow blade, the other with a loader. Plow on one side of the rock, loader on the other. Push.
Bruce
Some of you guys misinterpreted the BIG ROCKS I was referring to. The big monsters aren't really much of a problem. I meant those ugly 70 to 400 lb sort. Those are the ones I end up chasing around. The big problem around here with the "take a little dirt" is simple. The dirt is very little and the brother of that big rock is right there with his friends and the bucket skips right off. I don't want to use my tooth bar either just for that reason. I save that for brush and small trees
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #39
A little help goes along way.
   / How Do You Guys Coax Big Rocks Into Your Bucket???? #40
How does that "pusher" fare in the unloading process?
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2019 Ford Explorer (A55788)
2019 Ford Explorer...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
