How do you clean your greasy loader pivots?
   / How do you clean your greasy loader pivots? #1
Shawn T. W.
Platinum Member
SW Missouri Ozarks
Massey Ferguson GC 1725 MB - Kubota L5030 - John Deere Z960M
While my little tractor is no garage queen, and I'm not home a lot, so I rarely get a chance to "clean", just use!
A few weeks ago … I decided to give my Little Baby Fergie a good clean up ...the grease migrates out of loader pivot points when I get into heavier brush and makes a mess!
I went through nearly a roll of paper towels cleaning the grease, grime, and weeds out, then sprayed it down wiped some more ... Then washed with a cloth and dawn dish soap …
Not perfect, but a lot less likely to grease up my clothes!
Since she was mostly clean, and it had been over a year since I had waxed her ... I put some shine on her! Yes, it's a work tractor!
While I have sporadically cleaned and waxed "around" the greasy spots in the last 39 months since I bought it, I have never been shy about greasing in the 669 hours of use ... Has more now!
But the next time through the brush, I'll probably be running branches up through the pivot points and spreading grease ... Is there a way to prevent that? Or is it just the way it is?
Is there a good way, other than a STEAM cleaner to remove the old stuck on grease and gunk? (I couldn't get it all off!) I'm thinking “clean more often”?
   / How do you clean your greasy loader pivots? #5
In all of the years that I've my 4105 (new, Feb '13) I have never cleaned any of the excess grease resulting from a grease nipple/zerk.
If there's a nipple, it gets grease. If it moves, but doesn't have a nipple, it gets a good spray of lanolin lubricant.
I may have washed it once... when I was young. ;) It lives in an open-bay shed.
   / How do you clean your greasy loader pivots? #6
I have been using commercial grade Oven/Griddle cleaner like is used in restaurants. Spray on and rinse off. Grease, oil and dirt just wash away. If there is really thick grease some brushing is necessary. Be careful some paints can be removed with this product, usually rattle can or fresher paint.
   / How do you clean your greasy loader pivots? #7
I use diesel fuel and LOTS of cloth rags. I also agree with the idea that grease prevents rust so tend to leave the extra on there until it starts to get excessive. I believe using any kind of pressure washer on greased joints is asking for trouble, so I just wipe it down by hand.
It helps if you keep it cleaned up while you are greasing, rather than just letting what squishes out stay there. Even at that, I always try to leave a little on there.
Just for information, I had a hard time removing exhaust stains from my hood, but found that Turtle Wax liquid car wax removes it quickly.
   / How do you clean your greasy loader pivots? #8
Power wash for me is the clear winner. once a year. i wouldn't make a big deal of it.
   / How do you clean your greasy loader pivots? #9
I have done this and it tends to blow appart the grease but then spreads it all over the machine.
What's the best way..idk as I dont clean mine like that.
   / How do you clean your greasy loader pivots? #10
i usually apply copious amt of Simple Green, let soak a while then pw. wipe down any excess afterword. but i only do once annually. i never was bothered with excess grease, best regards
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2010 Cadillac SRX SUV (A56859)
2010 Cadillac SRX...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2024 DIGMASTER MINI EXCAVATOR (A58214)
2024 DIGMASTER...
