How do you attack it?
/ How do you attack it? #21
Rob, did you drive over that stuff, or back through it? What you did sure looks good.
Hey Chuck, I drove over it. My little TSC 4' bushhog isn't that heavy and even small stuff will send it in the air. The first pass is the hardest because it's a full 4' wide, that I will try and zig-zag to the smaller stuff. Then bite off a little at a time if I can. I'll keep it up high at first to. HEck some of the trees will make my L2500's front end ride up off the ground. :D
In the end, I won't usually try anything much over 1.5", maybe 2" if I know it to be a real soft green weed.
/ How do you attack it? #22
Well, I am a little slow, but not that bad. I was dropping a tree at the time, and as the tree started going down, the limb came down and hit me. I was busy getting away from the tree, so it was a minute latter that I remembered the limb hitting me. It was probably only 15 feet high in the tree. If it had been higher, it might have hurt.
