How do manufacturers paint tractor attachments?
   / How do manufacturers paint tractor attachments? #11
I've noticed it acts like old style automotive undercoating did.
Flakes a bit and rust creeps under the skin staying trapped until a blister bursts leaving a pitted rusty area.
   / How do manufacturers paint tractor attachments? #12
I honestly believe they drag them outside, let a rust haze form on the metal, then let a very inexperienced person paint them with finger paints or maybe a mop if they have gradjimicated to master painter.
My Case backhoe hood lost all its paint and began to rust in 1 year. My Woods Batwing mower began losing paint in about a year.
   / How do manufacturers paint tractor attachments? #13
Easiest way is to have item sand/media blasted and primer immediately.... The cost of media blast is way cheaper than you doing it your self when you apply a hourly rate to your time. yes you say your time is free, well it ain't true if you consider food, lodging, materials, and other work not getting done...
   / How do manufacturers paint tractor attachments? #14
20 some years ago, Deere would paint disk gangs, trip assemblies for various ground engagement implements and a host of other small parts/assemblies that were hung on a conveyor line, with a hot water pressure wash and hot rinse and a chemical rinse somewhere in the mix. Then a quick hot blow dry and off to the paint booth where they would be dipped into a huge tank of black paint or a spray paint booth. Then into a long hot oven for drying.
When the conveyor line exited the oven they were sent to shipping warehouse.
   / How do manufacturers paint tractor attachments? #15
"Easiest way is to have item sand/media blasted and primer immediately.... The cost of media blast is way cheaper than you doing it your self when you apply a hourly rate to your time. yes you say your time is free, well it ain't true if you consider food, lodging, materials, and other work not getting done..."
About 12 years ago I bought a used blower.
Took it to a DIY sand blasting installation, did a complete blasting job, brought it home and immediately primed it with Tremclad primer.
Now 12 yrs later only the 'impacted parts', like fan and chute have lost paint. All the rest of that blower has retained the original finish.
I still, to this day, feel that the time invested back then was well worth it, helped in that the used buy was a good deal, especially since I got 12 years good service with many more to come since I recently changed all the bearings and did minor repairs.
   / How do manufacturers paint tractor attachments? #16
I bought a tiller last October and just for grins I wiped it down to get any dirt or oil off and sprayed the whole thing with Rustoleum clear. So far it looks pretty much like it did when I got it sans the tines and shaft.
   / How do manufacturers paint tractor attachments? #17
"How Do Manufacturers Paint Implements"......
Some... Very badly... I have a China made box blade that looks like a job I would do with spray cans... It doesn't matter as it does the work I need it to do, and I don't require keeping things "show room" sparkle...
The things I have built and painted that stayed the nicest the longest.. I did power wire brush, or sanding disk cleaning.. Wipe down with alcohol, paint thinner, brake cleaner on a rag.. Painted with implement enamel using a cheap throw away brush.. It seems it takes a long time to dry to a hard finish.. Longer for the drips, and brush marks to dry..
Pretty much the same procedure for used equipment...
It doesn't look bad from a distance.. And is much better protected than with no attention at all..
That is all I require..
   / How do manufacturers paint tractor attachments? #18
The DH Atlas rotary cutter and box blade I got new in March are losing the paint. The rotary cutter is losing paint on top of the deck and store it inside a shed. I expect it to lose paint on the sides when it rubs everything. My DH Sunshine grapple, also stored inside, is showing rust in a few spots around the hinges. Paint left the contact surfaces the first time I used it, but that is to be expected.
   / How do manufacturers paint tractor attachments? #19
You'll find that the Rustoleum is a perfect match for late model Kubota Orange II as well. Magic enamel is a dead match for early Kubota Orange I.
"Magic" paint is junk!
   / How do manufacturers paint tractor attachments? #20
Implement manufacturers don't "paint"!
They just spray color on their implements, to make them look shiny going out the door!
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Caterpillar 906M (A53317)
Caterpillar 906M...
