How do I set up a hyd. top link?
   / How do I set up a hyd. top link? #11
Question: If you only need the "top" portion is is important to get a cylinder with the check valve??
I read ccm's explination and cannot see how a "top" could fall on you ever.
Is the only need for the check valve for OSHA compliance?
I was looking at Hydraulic Center's web site and they have what I need for $122. I would like to keep $50 difference if I don't need the check valve. Is there a quality difference between ccm and Hydraulic Center?
   / How do I set up a hyd. top link? #12
I have the Deere OEM hyd top link. It doesn't have the internal check valves.
The cylinder "loses" it's position after you turn the tractor off. Not immediately; but, if you leave the tractor for a few hours and the implement is on the ground - little or no weight on the 3pt - it will change.
It's not a big deal.. it's a small irritant that I have to readjust the in/out tilt of my rear blade or the depth that the tiller will dig once I fire up again and get going.
As far as the OSHA/safety issue - it's a "non-issue" - IMO. Deere and anyone else selling non-check valve hyd cylinders wouldn't do it, if they thought it was a problem. And personally, I can't really imagine how the cylinder could "rapidly" depressurized and catch anyone under it (if they worked at it; someone might find a way). That said; anyone who works under heavy 3pt implements without significant safety precautions has more to worry about than the leak-down of a hyd top-link...
Save the $50; if keeping position of the implement isn't a big deal to you.
AKfish
   / How do I set up a hyd. top link? #13
There are times when I'm using my limb grinder for an hour or two, sounds like it would need periodic re-ajustment.
I can say that my CCM link does not leak. When I have the grinder mounted I can't set it on the ground because the PTO shaft is too short ( I wanted the unit as close to the tractor as possible, for manueverability .) So when not it use it stays suspended sometimes for weeks at a time, without moving.
   / How do I set up a hyd. top link? #14
Thanks Guys, I love this site, you get replys from the people using the stuff:)
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
golf cart (A55787)
golf cart (A55787)
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
