How do I remove the starter on an International 1586 with a cab?
   / How do I remove the starter on an International 1586 with a cab? #1
cdf
Eagle Bridge ,NY
IH
Need to replace the starter on an International 1586 with a cab. Have NO CLUE as to how to go about removing it. HELP!!!!!!!!!!!!!!!!!!
   / How do I remove the starter on an International 1586 with a cab? #2
Pull up the floor plate of the cab. Its right there where u can get to it. If u have it rebuilt, be sure to tell em its off of an international. The starters turn backwards from most since they mount behind the flywheel instead of in front.
   / How do I remove the starter on an International 1586 with a cab? #3
Oh yeah, once u get to it. Just disconnect the wires, after you remove the battery cables from the batteries, then theres just 3 bolts holding the starter to the bellhousing. A 9/16 wrench fits em.
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
2017 Rogator RG1300B Dry Fertilizer Applicator (A53472)
2017 Rogator...
2017 SKY TRAK 6036 TELEHANDLER (A52576)
2017 SKY TRAK 6036...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
