How do I remove a lower lift arm on Kubota L3710?
   / How do I remove a lower lift arm on Kubota L3710? #1
LabLuvR
SC
Kubota MX5400
I managed to break the lower arm and cannot figure out how to remove the arm from the tractor. I see one small bolt with some kind of plate but, when I remove the bolt the plate didn't move. What am I missing here?
Also, can the arm pieces be welded back, or do I have to buy a new one? Thanks!
   / How do I remove a lower lift arm on Kubota L3710? #2
If it is like my L3010 you have the right idea. That plate is a stop over the hole to keep the pin from sliding out. You will need to "persuade" it to move. Heat might help loosen it. It probably has been there a while.
   / How do I remove a lower lift arm on Kubota L3710? #3
Are you talking about the lower lift arm on the three point hitch?
Does it look like the one on my L3830? If not a picture would help.
Chris
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
Kubota RTV500 (A47384)
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
