How do I pull this pulley wheel off ?
/ How do I pull this pulley wheel off ? #21
I was in a similar situation last spring removing a large pressed steel pulley from the gear box of my Landpride rear finish mower. I tried everything; penetrating oil, heat, supporting the outside of the pulley and hearing plus tapping on the shaft, even a large gear puller (could not apply a lot of force because of the danger of bending the pulley). What finally worked for me was to use a dremmel tool and a sawzall to cut a slit in the hub of the pulley just above the keyway. This allowed the center to expand enough to slide easily from the shaft. Once the pulley was off I cleaned everything and prepped the pulley for welding. I put the pulley back on the shaft. It seamed a real good fit. I do not think the center hole had permanitly expanded. I tacked the pulley while it was on the shaft then removed it and finished the weld. It worked great.
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2021 KLX 300 Motorcycle (A61166)
2021 KLX 300...
2016 48ft. Fontaine Velocity 38 Ton T/A Flatbed Trailer (A61568)
2016 48ft...
Paladin 544K 416 IC 105in. Dual Cylinder Hydraulic Loader Attachment (A61567)
Paladin 544K 416...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
