How do I know if it needs rings ??
/ How do I know if it needs rings ?? #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
First lets clear the air ... I am no mechanic!! My old tractor a Long 360 smokes and uses a little oil. I am told it needs a ring job.
How do I tell? What can I expect?
/ How do I know if it needs rings ?? #2
Dose it smoke all the time or just starting?
All time is usually rings
At start up is valve guides
A compression test would tell which one it is too and give you a better idea if its one cylinder or more.
I'm not familiar with this tractor or engine this is just the basics.
tom
/ How do I know if it needs rings ?? #3
Is this a diesel motor?
/ How do I know if it needs rings ?? #4
As Tommu56 said. (Especially when you put your foot down, its rings).
You can buy extra thick oil especially made for older, smokey engines. It doesn't cost much more than ordinary oil and, in my experience, works quite well to reduce smoke. You'll need to go to a motor parts store to get it. A complete oil change to this type of oil is much more effective than a small bottle of 'stop smoke' additive.
/ How do I know if it needs rings ?? #5
Does it smoke all the time or does it come and go?
When is the last time you took the air cleaner apart and cleaned it?
/ How do I know if it needs rings ?? #6
You can take a compression test, then squirt in some 30 weight oil and retest. The oil will temporarily seal the rings and boost the compression if they are bad.
/ How do I know if it needs rings ?? #7
Best way to tell if rings are bad is a cylinder leak down test. Google it you should find lot's of info.cylinder leak down tester is simple tool used with compressed air to tell how much air is going by rings.Should find used tools on ebay resonable
/ How do I know if it needs rings ?? #8
Sometimes rings will just smoke at startup too. Had an 88 Mazda pu that smoked like a fogger at startup. Previous owner had valve seals done thinking that was the cause.
I tore it down and found the oil control rings were all gunked up and sticking badly. Put new rings in and -voila- no more start up smoke.
BTW that motor had 210,000 on it and the cylinder crosshatch still looked good. Didn't even have a ridge at the cylinder tops. Lightly touched it with a hone and put it back together...I think that motor would have gone another 210,000 no problem but it got totalled in a wreck:(
/ How do I know if it needs rings ?? #9
ditto what the others said.. on a wet test.. numbers that come up indicate rings.. could do the same with the leakdown test..
soundguy
/ How do I know if it needs rings ?? #10
You will probably need new rings and pistons what color is the smoke how much oil is it using normally the sleeves will be the same dia as new. piston with ring about $100 x3=$300 gasket set about $90.
You could probably just get away with pistons but rings are cheap enough
/ How do I know if it needs rings ?? #11
It wouldn't have gone so fast had you not fixed the rings :D
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2012 Komatsu PC360LC-10 (A61166)
2012 Komatsu...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
UNUSED INDUSTRIAS AMERICA F08-8' LAND LEVELER (A62130)
UNUSED INDUSTRIAS...
New/Unused Leaf Blower (A61166)
New/Unused Leaf...
2007 Ford Focus Hatchback (A61569)
2007 Ford Focus...
