How do I know if I have a HSTC-3?
   / How do I know if I have a HSTC-3? #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
Anyone know how to tell the differences of hst vs hst-3?
TIA!
   / How do I know if I have a HSTC-3? #2
One difference is;the HST use a lever for PTO engagement ,the HST-3 uses a pull-up button.I am sure there are other differences also.
None of the above, so must be a 1 or 2..
Thx
   / How do I know if I have a HSTC-3? #6
Yep the stock seat on an L40 HST-3 swivels. There is a pedal right in the front you pull up on and swivel until it clicks and locks in place.
   / How do I know if I have a HSTC-3? #7
The C means Cab. That part should be obvious... Not sure what they added later on with the 2-speed HST motor or the auto throttle stuff. Maybe that was there from the beginning.
   / How do I know if I have a HSTC-3? #8
My older M9 is an HDCC3 which denotes Hydraulic Shuttle Cab Creep gears which adds 3 ranges to the gearbox. Note, the 2 speed pto (540 / 1000) has no model letter designation.
My seat swivels as well and it's air ride too.
That's exactly what I don't understand. Does the 3 mean 3 ranges? I have cab, lever PTO, auto throttle advance, turtle/rabbit speeds....
Woods says they have a subframe but it's for HSTC-3
   / How do I know if I have a HSTC-3? #10
TIA!
Does your tractor have at serial number sticker on dash? My M7040 does and it shows my tractor is a HDC-1 so your model might be listed on sticker if it has one.
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
TMA (A49461)
TMA (A49461)
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A51692)
2015 Ford F-250...
International Acid Tanker Truck (A52377)
International Acid...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
