How do I get the knobs off?
/ How do I get the knobs off? #1
NokesvilleBoy
Kubota BX24
On my Kubota BX24, I'm trying to remove my rear fender so that I can get to the propeller shaft and replace a busted HST fan. I need to remove the lowering speed adjusting knob and the MMM height adjustment. I can't find a set screw or anything else to loosen. I've tried just pulling, but not too strongly. Any idea on how to get them off?
Also, I need to disconnect the electrical outlet. There doesn't seem to be a lot of working room to get to the connector. It's in between the fuel tank and a mounting backet. Do I just slide in a screw driver and lever it off?
Appreciate any good advice
/ How do I get the knobs off? #2
I don't know anything about the other stuff, but the MMM deck height adjuster on mine was a push on and yes it is hard to get off.
/ How do I get the knobs off? #3
TripleR,
If you have a heat gun, play a little heat on the levers knobs and they should start to move - they slide on and take a set in time.
This works unless someone added some weatherstrip adhesive, they will slide off with a little tugging.
Good luck!
/ How do I get the knobs off? #4
Have you done a search here on replacing the fan? There have been many threads on this issue and how the fix was accomplished. From what I recall, most fixes were done from below without removing the rear fender deck. I believe the most common approach is to loosen the motor mounts and "slide" the engine and drive shaft forward to remove the fan.
Due to the difficulty of r&r of the fan, many of us BX owners have added a skid plate for protection. Give that some thought once you fixed yours. Good luck.
/ How do I get the knobs off? #5
Study those threads. It will save you some work.
Do you have the kubota insurance. I believe it will pay for the dealer labor and part replacement less deductable.
2022 EZ-GO ELITE...
More info coming soon. (A64557)
More info coming...
6 Band Wood Barrel (A64557)
6 Band Wood Barrel...
2000 International 4700 Altec AM655 55ft. Bucket Truck (A64194)
2000 International...
Dixie Chopper Zero Turn Commercial Mower (A64553)
Dixie Chopper Zero...
2013 Caterpillar 305.5E Mini Excavator (A64553)
2013 Caterpillar...
