How do I check the speed of the mid mount PTO?
   / How do I check the speed of the mid mount PTO? #1
Looking4new
Super Star Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
According to my owners' manual the mid mount PTO is supposed to turn at 2000 RPM. How do I confirm this?
   / How do I check the speed of the mid mount PTO? #2
Doesn't your tachometer have a "PTO" marking on it? That would be for 540 rpm on the rear and (normally) 1,000 on the front. Yours apparently is 2,000.
Ralph
   / How do I check the speed of the mid mount PTO? #3
Ralph
Your 1025's front PTO spins at 2000 rpm as does most other CUT's
   / How do I check the speed of the mid mount PTO? #5
Laser tach.... I use them all the time at work to measure fan speeds in PC's. Work great. We use a Monarch. It is nice, because for accuracy work it can be NIST and 9001 calibrated. I typically measure anything from 1rpm-3000rpm.
http://www.zorotools.com/g/00056201/k-G2022946?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CKie_M2U4bsCFYw1QgodLCgANA
A web search for "Laser Tachometer" shows cheap ones for $16 to $50
Amazon.com: digital laser tachometer
Thanks people. I never thought of those.
I just ordered one.
   / How do I check the speed of the mid mount PTO? #7
Normally the PTO is a fixed speed that tracks with the engine RPM. The PTO rated speed is usually at the MAX engine RPM. On newer tractors that is at wide open throttle. I don't run mine that fast very often.
Ron
When my tack comes (ordered) then I will confirm that the mid PTO is revving the 2000 rpm it is supposed to. My snowblower isn't throwing the snow as far as I think it should. At 2600rpm dry powder snow is only going about 12'. I don't think it is the fault of the PTO, but I need to start somewhere and that is as good a place as any to start and the cheapest.
Next option is to change the gearing in the transmission at the front of the mount. That will co$t me anywhere from $500.oo - $1,000.oo
   / How do I check the speed of the mid mount PTO? #9
I bought my laser tach very cheaply on E-Bay, from China! Works great! I see tht some have both a laser and physical contact point.
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
1999 FREIGHTLINER FL80 SWABBING UNIT TRUCK (A58214)
1999 FREIGHTLINER...
Butterfly Artwork (A55758)
Butterfly Artwork...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
