How do I check the speed of the mid mount PTO?
   / How do I check the speed of the mid mount PTO? #1
Looking4new
Super Star Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
According to my owners' manual the mid mount PTO is supposed to turn at 2000 RPM. How do I confirm this?
   / How do I check the speed of the mid mount PTO? #2
Doesn't your tachometer have a "PTO" marking on it? That would be for 540 rpm on the rear and (normally) 1,000 on the front. Yours apparently is 2,000.
Ralph
   / How do I check the speed of the mid mount PTO? #3
Ralph
Your 1025's front PTO spins at 2000 rpm as does most other CUT's
   / How do I check the speed of the mid mount PTO? #5
Laser tach.... I use them all the time at work to measure fan speeds in PC's. Work great. We use a Monarch. It is nice, because for accuracy work it can be NIST and 9001 calibrated. I typically measure anything from 1rpm-3000rpm.
http://www.zorotools.com/g/00056201/k-G2022946?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&kw={keyword}&gclid=CKie_M2U4bsCFYw1QgodLCgANA
A web search for "Laser Tachometer" shows cheap ones for $16 to $50
Amazon.com: digital laser tachometer
Thanks people. I never thought of those.
I just ordered one.
   / How do I check the speed of the mid mount PTO? #7
Normally the PTO is a fixed speed that tracks with the engine RPM. The PTO rated speed is usually at the MAX engine RPM. On newer tractors that is at wide open throttle. I don't run mine that fast very often.
Ron
When my tack comes (ordered) then I will confirm that the mid PTO is revving the 2000 rpm it is supposed to. My snowblower isn't throwing the snow as far as I think it should. At 2600rpm dry powder snow is only going about 12'. I don't think it is the fault of the PTO, but I need to start somewhere and that is as good a place as any to start and the cheapest.
Next option is to change the gearing in the transmission at the front of the mount. That will co$t me anywhere from $500.oo - $1,000.oo
   / How do I check the speed of the mid mount PTO? #9
I bought my laser tach very cheaply on E-Bay, from China! Works great! I see tht some have both a laser and physical contact point.
PALLET OF SCRUBBER PODS (A58214)
PALLET OF SCRUBBER...
Bell 1600 Gallon Nurse Trailer (A56435)
Bell 1600 Gallon...
17506-FL (A56857)
17506-FL (A56857)
2019 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2019 Peterbilt 389...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
