How do I check coolant level on my B7100?
   / How do I check coolant level on my B7100? #1
GDITheman
How do I check coolant level on my B7100? The owner's manual doesn't mention it. I wanted to see if I need to add any.
I figured I could just look, but is there a certain level inside the radiator it should be at? Can there be too much? I'm used to having a resevoir to view.
The manual states 50/50 mix, but I've seen some people here say 70/30 mix.
   / How do I check coolant level on my B7100? #4
A good level is probably 1-1/2 inches below the cap. The antifreeze mixture would depend on how cold you area gets in the winter. 50% antifreeze would be the maximum recommended.:D
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
*Selling at Royal Auction Tampa, FL Location* 12 (A59230)
*Selling at Royal...
CAT 336E (A58214)
CAT 336E (A58214)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
