How dangerous is YOUR PTO?
/ How dangerous is YOUR PTO?
I agree. I have almost never left the seat with the PTO running. The last time I did, I was brush hogging and had to step off to pick up a big chunk of concrete. I certainly wouldn't go anywhere near the shaft. I treat it like a sawmill blade. Even after disengaging the shredder, it spins for a good 2 minutes.
For me, the cover isn't necessary, although I'll probably replace or fix it at some point. I'll still never give myself a chance to tangle with it. Sounds like most of us see it the same. (Basically)
/ How dangerous is YOUR PTO? #22
Let me offer a tip.
When disengaging a PTO implement I always throttle the tractor to an idle before disengaging. This brings the PTO shaft to idle speed and dramatically shortens the "run on" time. I do this because I'm 63 years old. By the time I get off the tractor I'll forget I even had the PTO implement running and walk right into it.
Let me offer a tip. When disengaging a PTO implement I always throttle the tractor to an idle before disengaging. This brings the PTO shaft to idle speed and dramatically shortens the "run on" time. I do this because I'm 63 years old. By the time I get off the tractor I'll forget I even had the PTO implement running and walk right into it.
Good tip. Just this week I loaded the tractor on the trailer after finishing with the shredder. I disengaged it way before I loaded it, but still waited a minute or 2 before I chained it down for the shredder to stop. At least I know all the bearings are good! Ha!
/ How dangerous is YOUR PTO? #24
Most tractors have a PTO brake. I idle down to reduce wear on that brake. Obviously your tractor does not have one, or it is non-functional.
If equipped, it's purpose is to prevent the run-on you are describing. When the tractor engine is turned off, it releases. This is so you can turn the tractor shaft to align the splines when hooking up a PTO shaft. If you can turn your shaft when the engine is running, you definitely don't have one.
/ How dangerous is YOUR PTO? #25
I replaced my missing shield with a lenght of plastic drain tile works pretty good at keeping the debris from wrapping up
Most tractors have a PTO brake. I idle down to reduce wear on that brake. Obviously your tractor does not have one, or it is non-functional. If equipped, it's purpose is to prevent the run-on you are describing. When the tractor engine is turned off, it releases. This is so you can turn the tractor shaft to align the splines when hooking up a PTO shaft. If you can turn your shaft when the engine is running, you definitely don't have one.
Definitely don't have one. Dual stage clutch, but no PTO brake. Never caused a problem, just a minor inconvenience sometimes like previous example. Like you said, throttling down would solve it all. When I was traveling back to the truck in high gear I just knocked the PTO engage handle down, so it was at full rpm at that point.
I was considering something similar. The problem with my shredder setup is, if i raise the lift ALL the way up, the shaft contacts the top front edge of the deck, cutting the shield. This one was done this way before I bought it, but I've also lifted it too far countless times since.
/ How dangerous is YOUR PTO? #28
Very good idea. Might have to play with it a little to get the length right so you could still hook/unhook PTO shaft. In my case it would ride down next to the tractor, which is where any wrap problems are going to happen. Thanks for the tip!!!
/ How dangerous is YOUR PTO? #29
Let me offer a tip.
Then it probably takes you two minutes to get off the tractor..:laughing:
My old 4' bush hog had remnants of a PTO cover when I bought it. I stripped it bare and used it with care. I'm still new enough to tractors that I shut it off before I leave the seat - my size 14 feet tend to disturb levers as I mount/dismount. I prefer to avoid the indignity of being run over by my own tractor.
/ How dangerous is YOUR PTO? #30
I've never had to replace the plastic shield/cover. I bought an entire new shaft when I got the new tractor & I think it was around $300. I would seriously look into plastic drain pipe etc prior to paying $200 for a new shield.
However, I would want to be certain the plastic df pipe was doing the job. It makes me shiver just to think of my flannel shirt beginning to wrap around the PTO shaft.
/ How dangerous is YOUR PTO? #31
I'm not that bad yet. But I've gotten off the tractor and walked around to the brush cutter and the shaft is still idly spinning. Which means if you stick your toes under it you are probably going to need a pedicure at a minimum. :)
/ How dangerous is YOUR PTO? #32
I've told this story before. But it's worth retelling.
30 years ago I was still watching TV from an Antenna. Watching Des Moines Iowa evening news. Reported a 10 year old who had gotten both of his arms ripped off at the shoulders by a grain auger PTO shaft. Parents weren't home. He went in the house and sat in the bathtub until his parents came home. His biggest worry was that he had bled all over the house.
/ How dangerous is YOUR PTO? #33
Your PTO will also be unsafe if you replace the shear pin with wire. Here's what happened to a friend of mine: She was driving a tractor with a shredder. Someone had replaced a broken shear pin with a piece of wire. The lady hit a solid object which caused the back end of the PTO to break loose from the gear box, allowing the still rotating shaft to fly up and hit her in the head and put her into a 6 week coma. This happened years ago but the brain damage lingers on. Worthy of note, the old tractor she was driving was before ROPS were standard equipment.
/ How dangerous is YOUR PTO? #34
PTO shafts are very dangerous and require constant respect and attention. My newer attachments have functioning covers but my older stuff has nothing, I use the same rule for any pto shaft, if the pto is engaged stay out of arm/clothes/etc reach.
I've told this story before. But it's worth retelling. 30 years ago I was still watching TV from an Antenna. Watching Des Moines Iowa evening news. Reported a 10 year old who had gotten both of his arms ripped off at the shoulders by a grain auger PTO shaft. Parents weren't home. He went in the house and sat in the bathtub until his parents came home. His biggest worry was that he had bled all over the house.
As terrible as that is, he's fortunate it wasn't worse. Obviously didn't wrap him up...
My wife's grandpa is missing his right arm at the shoulder from a hay baler accident. Back in the day, before the word safety was invented, he was shoulder deep removing a clog in the baler. Not sure of the details, but someone engaged the tractor before he was done. Hanging on with his left arm is the only thing that kept him from going all the way in.
/ How dangerous is YOUR PTO? #36
My augur cover is perfect, always seems to be someone back there guiding it. Brush hog cover is in several pieces not much value, but no one ever near it. Never get off tractor with pto running . Frankly the thought of getting caught in it scares me badly. I am prone to push the limits most of the time, but not with pto.
/ How dangerous is YOUR PTO? #38
Ask the members of your your local rural fire department, rural cops and hospital ER staff how people are injured with pto shafts.
/ How dangerous is YOUR PTO? #40
All my shafts are covered. If one broke I'd replace it. It's one of those things where if you need the cover you basically get one chance, there's no minor "I got caught in the shaft" accidents. Unlike something like a seat switch it's a hugely dangerous mechanism and something as simple as tripping or having something fall into the shaft can have huge consequences. I lost my chains and use a bungy now to keep the plastic covers from spinning. They also double to hold up the shaft when the implement is off.
Gehl RS6-34 (A64119)
Portable Chicken Coop (A66408)
Portable Chicken...
2018 BOBCAT MT85 STAND-ON SKID STEER (A65053)
2018 BOBCAT MT85...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2006 Ford Freestyle (A64557)
2006 Ford...
Case 222 Garden Tractor (A66408)
Case 222 Garden...
