How cool is this mower
   / How cool is this mower #21
   / How cool is this mower #22
Messmaker - Fess up, If you want a Sherman tank - just go out and buy one. That's an interesting looking unit. However, it would be like most any 4WD vehicle - if it EVER DOES get stuck - it will be in a location that very few could get to, to give assistance.
   / How cool is this mower #23
What part didnt you know?
I have no doubt those tires have better traction, but I wasn't impressed with his video. I could easily do everything he did in the video with my turf tires. I also got pretty good about not tearing up turf when turning.
Not so much what the video shows, but what he says. My experience pretty much is the same as his. I tore up alot more turf with the standard tires. Going around trees, the nice ~6' diameter circle or whatever. THe standard tires had no grip. So you would make what appeared to be a nice 6' circle, however, either the inner or outer wheel could be slipping the whole way and you have no clue. The AT101's dont slip. They actually force you to hold the levers correctly.
Any tire will tear up the turf when doing a zero turn. The key is a K turn, or a three point turn.
Its hard to compare one guys experience to another, especially in a video where its really hard to get a good picture of just how steep slopes are. No two properties are the same. But having used both turfs and AT101's on the SAME property, the difference is huge. Dad still has turfs, and comparable mower. His is a bobcat ZT223 61" mine is a scag 61". Same tire sizes and all. There is a swale/ditch that separates out properties. In the spring it can lay a little wet in the bottom long after everything else has dried out. I can mow it when he wouldnt dare to. That tire running right in the bottom, will start spinning then hes done.
I guess, in summary, if you have no issues with turfs, dont ever mow a shaded hill and slide, or get stuck at the edge of a wet spot.....then turfs are for you. But if you have been stuck or slid down a hill even once, consider AT101's for your next tire. All the crap about tearing up the yard is BS. They are every bit as easy on the lawn and possible even less damage will be caused under normal conditions due to the rounded edges the guy mentioned in the video. But they have so much more to offer if conditions are even the slightest bit dicey.
   / How cool is this mower #24
Very interesting. I'm sure for certain situations it would be great.
It's very viable for MOST situations. The TRX has two decks available... one standard high lift, and a flail type rotary (mini bush hog).
The tracks were specifically chosen to provide excellent turf care. I have seen turf damaged more easily by wheeled units. I have demo'd these units. They're great at both finish AND rough mowing.
   / How cool is this mower #25
How many people have a need to mow the swamp????:)
Not many... but there are many other applications with wet/soggy ground/turf.
Water surrounds, drainage paths for right-of-ways, or poorly drained turf, etc.
   / How cool is this mower #26
Did you notice that it can be had with a rough cut mower?
The rough cut deck is a rotary flail type mower (mini bush hog type "swing blades" or "fulcrum blades"). The specs say up to 1/2" material... but I've witnessed 1" or better.
   / How cool is this mower #27
It certainly looks cool. I can't imagine it being able to mow a nice yard without tearing it up. I'd also guess it's expensive. I'll have to keep using my 4x4 B7200 to mow sketchy areas.
Pre-market MSRP projections are in the $18k range... VERY competitive with all commercial grade ZTRs, and even with some "pro-sumer" or higher midrange models.
   / How cool is this mower #29
Why are all the mowing shots of this thing in the wilderness? Who mows that stuff? If your trying to reclaim land, wouldn't you reclaim it first with a tractor then plant decent grass or pasture on it, then mow?
You've brought up a good point.
This machine actually outperforms such measures, ESPECIALLY in terms of intermittent mowing/clearing. Any ag tractor combination would result in serious soil disturbance in such conditions. The high flotation, lighter weight, lower ground pressure, and higher reactive area give this machine a distinct advantage.
As a matter of fact, it will go where most 4wd subcompacts would have a hard time, if not an impossible challenge.
   / How cool is this mower #30
I noticed that they didn't show it going down much of a slope. My zero turn has no problems going up, but going down can get interesting at times even with AT 101 tires.
The higher tractive area, along with the better weight transfer of the tracks ensure far greater down-slope traction.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2005 Military Trailer (A53424)
2005 Military...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 KUBOTA SVL95-2S SKID STEER (A52706)
2018 KUBOTA...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2014 FREIGHTLINER...
