how change hst fluid
/ how change hst fluid #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
How or what is involved in changing all the hydraulic fluid in the MX 5100HST.
/ how change hst fluid #2
I am not familiar with your tractor but it shouldn't be any different from any other. Remove the drain plug and drain the oil, unscrew the filter and install new one, put back the drain plug and refill with fluid.
Look at your manual to see the capacity of the hydraulic reservoir and make sure your catch pan has sufficient quantity to hold all the oil.
/ how change hst fluid #3
Make sure you remove all the drain plugs - there may be 2 or 3.
Like Gary said, make sure your drain tub is big enough to hold all the oil - no fun overflowing the tub.
I have a Rubbermaid clothes storage bin with a snap on lid that I used to do mine.
/ how change hst fluid #4
Pretty easy, you just need to figure out which plugs to remove (there may be multiple). Also may be two filters.
/ how change hst fluid #5
/ how change hst fluid #6
Don't forget the 2 rear plugs on the low points of the final drive cases on the rear axle.. If you are at the 400 hour point and are changing the fluid, I assume you will be changing the front axle fluid also. If you have any questions you can call me. If this is just your 50 hour, Kubota does not require changing the fluid, just both the hydraulic filter and the HST filter. I can help you with suggestions on that also.
Thanks guys just wanted to make sure it was as easy as drain and then refill. Guess now ill have to find a container big enough to catch all the oil
/ how change hst fluid #8
Dollar general has cheap 62 quart totes. You just need to have something that will clear underneath the tractor yet hold it all.. also dont forget it will be very heavy to move once it is full.
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
213137 (A64276)
213137 (A64276)
Caterpillar TH255C Forklift (A63688)
Caterpillar TH255C...
Kubota SVL95-2S (A64126)
Kubota SVL95-2S...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
