how can you check fuel shutoff solonoid
   / how can you check fuel shutoff solonoid #1
hkc3
decatur illinois
craftsman rider
I have a 4yr old crafstman 54incut, 26hp kohler, after it gets hot it loses power for a while then does fine, back and forth. i cleaned the carb, it had some varnish and sediment, but it still bogs down when hot, i can mess with the choke and it will run fine for 5 minutes then bog again. A mower tech told me it could be the fuel shutoff solonoid. Is there a way to check it before i drop 60 bucks on a new one. maybe some resistance check or something???? I have also replaced fuel filter and fuel pump.& the hoses look good. Thanks
   / how can you check fuel shutoff solonoid #2
Disconnect the fuel solenoid and unscrew the plunger and apply voltage and see if the plunger moves.
Clean the sleeve/housing the rod move in.
Full 12v?
   / how can you check fuel shutoff solonoid #4
Yes, all 12 v. Clean all fuel off the solenoid before you touch the wires with the 12v.
It only takes a little bit of grit to jam the plunger. Work the plunger until it is free.
I have done this many times.
   / how can you check fuel shutoff solonoid #5
Don't forget the ground side of the equation.
It MUST have a good ground.
Worked thanks
City of Lakeland (A51691)
City of Lakeland...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
1974 IH Farmall 1066 Tractor (A50514)
1974 IH Farmall...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
Dion 1224 XC Silage Chopper (A50515)
Dion 1224 XC...
