how can you check fuel shutoff solonoid
   / how can you check fuel shutoff solonoid #1
hkc3
decatur illinois
craftsman rider
I have a 4yr old crafstman 54incut, 26hp kohler, after it gets hot it loses power for a while then does fine, back and forth. i cleaned the carb, it had some varnish and sediment, but it still bogs down when hot, i can mess with the choke and it will run fine for 5 minutes then bog again. A mower tech told me it could be the fuel shutoff solonoid. Is there a way to check it before i drop 60 bucks on a new one. maybe some resistance check or something???? I have also replaced fuel filter and fuel pump.& the hoses look good. Thanks
   / how can you check fuel shutoff solonoid #2
Disconnect the fuel solenoid and unscrew the plunger and apply voltage and see if the plunger moves.
Clean the sleeve/housing the rod move in.
Full 12v?
   / how can you check fuel shutoff solonoid #4
Yes, all 12 v. Clean all fuel off the solenoid before you touch the wires with the 12v.
It only takes a little bit of grit to jam the plunger. Work the plunger until it is free.
I have done this many times.
   / how can you check fuel shutoff solonoid #5
Don't forget the ground side of the equation.
It MUST have a good ground.
Worked thanks
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
10855 Pumping Unit- ENGINE ONLY (A52128)
10855 Pumping...
20' One Trip Shipping Container (A50514)
20' One Trip...
