How big of a disk setup for a BX24?
   / How big of a disk setup for a BX24? #1
fishpick
Platinum Member
The part of NY with high taxes
L4760 & BX24
What's the biggest disk setup out there for a BX24? I know the rule of thumb for ground engagement is the width of the rear... but a disk is a little different beast and can go bigger...
Anyone running a 5' setup in sandy soil with some rocks? What about a 6' setup?
Whatca got? This would be ground already turned with a plow...
   / How big of a disk setup for a BX24? #2
Two concerns I would have are the weight and maybe the bumpiness. A harrow doesn't really create much resistance. I don't think your BX would have any trouble pulling a 6' harrow through the soil. I have a 6' harrow I use on a larger tractor that I think weighs about 500 lbs. We have sandy soil, but it's pretty rough going when smoothing it out after it's been plowed. I use an old 45 hp ford for the job. I wonder if you would do a lot of bottoming out on a BX.
It really depends on the conditions. If you're plowing soil that has established grass in it, you're going to end up with big clumps after plowing that I don't think a BX could handle driving through. If it doesn't have grass or thick weeds and it's sandy you might be able to get away with just harrowing and skip the plowing.
I use my BX 2350 to cultivate between the rows in a 2 acre garden and I came very close to buying a 4 foot harrow for the job. Instead I bought a cultivator with Danish tines. It has worked so well that I do not think I'll need to plow next year, just harrow, which a lot of ag people are in favor of because it doesn't dig up deeply buried weed and grass seeds.
The land is a 5-6 year neglected hay/soybean field... (I put both because I don't know what it was when abandoned)...
There will be lots of grass clumps - no doubt... But I have worked areas similar to this in years past with an old Wheelhorse - a 1 bottom - and a drag behind cultivator - and had good results.
I'm just wondering how big of a disk the BX can handle... bottoming out on sod clumps is nothing.
Cool video - but how many axles / transmissions / drive train anything have you tore out of that poor BX? Those tires in their setup are CRAZY!
That said - that's a good sized disk setup you have there.
   / How big of a disk setup for a BX24? #6
There is also a video of the Landpride 05 series disc in operation at their website........ on a BX.
   / How big of a disk setup for a BX24? #7
What model Wheel Horse?
RayCo - An old 16 horse Kohler under the hood I think...
Man - does nobody run disks behind their BX24?
   / How big of a disk setup for a BX24? #9
I guess tillers are in favor these days, especially with the smaller tractors, but there are people that use discs with good results. Do a search on posts by Milkman, and you may find something. I would think that the 4', and 5' discs would work fine. Landpride has a video showing their 05 series being used on a BX. Hmm, maybe I can find a picture of Milkman's setup.... Yes, I found a couple. Sure looks bigger than 4' to me! :D
   / How big of a disk setup for a BX24? #10
The soil is the biggest key. In Chucks pictures I only see the disk going in the ground a few inches deep. The soil doesn't look that sandy. I just ran the disk over my garden which is a true sandy loam(locals call it sugar sand). No rocks. With my lightweight L and a light duty 5' disk, after a couple passes the ground is very soft and the disk will sink to their axles...thus burying my tractor. 4wd won't do much either. This same garden would bury a 10' disk on a 55hp tractor. Not sure how the rocks would react to all this.
Now I have used my 5' disk on some harder clay type soil, in that stuff I could only get down 2-4 inches(with a weight on the back). No problem pulling it in that stuff.
First pick is the sand, second is the clay. Good Luck, Rob
