How big a bucket can I put on a Kubota M5040 with LA1153 loader?
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #1
jkahan
Bronze Member
Hi folks -
I have a 2007 Kubota M5040HDC (cabbed -yes I am spoiled). The bucket that came with the LA1153 loader is 72" wide and roughly 26" deep and high. A bunch of welds are coming apart so I am toying with the idea of just fixing it or getting a new bucket. If new, I am wondering how big a bucket I can put on and not sacrifice safety.
I have the LA1153 specs but I don't have a good sense of how this translates into operational reality with bucket selection. Width-wise, I wouldn't mind a 78" bucket. Deeper would be awesome. HLA has a heavy duty model that is 41" deep and 34" high. Love some opinions / advice. thanks. -- Josh
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #2
Hi folks -
Depends a lot on your workload, what you do mostly, what you use the bucket for. I use a CAL brand 4-in-1 bucket 76" that I call a 'pinch bucket.' Allows me to pick up logs, brush, rocks, etc cleaning up an old farm. It is a skid-steer quick attach compatible type. You need the 3rd function up front for that. One of the most useful things I have seen -- and the bucket will not rust out of that thing in this lifetime. Very thick and heavy duty. But it also weighs around 1000 lbs (which does not bother my MF 2660 which is an 81 horse weighing a good bit more than your 5040.)
One of my friends uses a 3rd party loader and bucket on their 5040 -- Bush Hog brand I think. It too is very solid but is a one piece bucket , not 4-in-1. Really you have a LOT of choices. Is your's equipped with the skid-steer compatible loader? If so there are a huge number to pick from. One caution: Some buckets designed for skidsteer have the mount at a different vertical level than your standard tractor buckets. (higher 3" or so, well the bucket sits higher so I guess the mount points on the bucket are lower) which means some oddball leveling/digging and back dragging circumstances.
p.s. of course it makes a big difference whether you are moving gravel, horse manure, soil, marsh muck, snow , etc. The lighter the material the bigger a bucket you can handle obviously. I adapted a much bigger bucket (than std) to a small Kubota just for snow removal as snow is very light compared to soil or gravel.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #3
I have a 72" bucket. It was OEM with my 2009 M6040. I haven't used it in seven years. Seven years ago I purchased a Land Pride grapple - WR Long valve and it's been on the FEL ever since.
Bucket width means nothing to me. I use the grapple to move large rocks, chunks of pine trunk and the occasional brush pile.
I would imagine your tractor/FEL would handle most any size bucket - within reason.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #4
I would suggest sticking pretty close to what you've got. Deep buckets, like the ones made for skid steers, don't work well on ag. loaders because of limited lift capacity and break out force. The load is moved out away from the pins and really limits any digging power. JWR is correct. Much has to do with what your use is. Additional width can be a problem if the bucket isn't evenly loaded. Think twisted loader arms.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #5
my M8540 came stock w/84" bucket, but i chose to go 72". i don't like to have a bucket width extend much beyond my fr wheels that can snag fence posts, trees, etc. if you're not careful. also feel it may have slightly more excavating ability being slightly narrower than stock. with a heavy duty tooth bar, i have been well pleased with utility use.
odd that your welds are failing on your bucket?
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #6
All depends what you are intending to do with it. Boulders, vs, sand, vs, snow, vs corn, vs gravel, well you get the point. Digging (which an ag tractor isn't meant for) or removing from a pile?
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #7
I have an MX5400, which per the spec is just shy of 6 feet in overall width and equipped with an LA1065 loader, (so ~2300 lbs lift capacity at the pin, model number is lift capacity in kilograms).
The bucket I bought with the tractor is an L2296 heavy duty bucket, 6 feet wide. For reasons I don't understand I cannot find an online specification for that bucket at the moment. The bucket weighs approximately 400 lbs. The bucket is sized about right so that I can fill it with heavy gravel loads and the tractor will deal with it. It holds approximately 9 cubic feet.
That's great for gravel, not so much for bulkier/lighter materials. In fact my two cats can easily generate enough kitty litter to fill that bucket more quickly than you'd imagine.
I'm now shopping for the largest light materials bucket I can get away with for bulky but light items. I'm shopping for an 84 inch bucket, so it'll definitely be wider than the tractor by a foot. I could probably get away with an 96 inch bucket, even my dealer didn't say "don't do that" when I asked.
Most of the 84 inch super large capacity buckets I'm considering are 35 cubic feet or greater (struck capacity), and most of of them at that capacity weigh around 750 lbs.
Should work but I won't be putting gravel in it, I I'm sure even bark mulch would weigh too much (or challenge my tractor dynamics in some way) if I filled it with mulch.
I can't tell you how that's working yet, but I run these things by my dealer and he's certainly willing to sell me buckets wider than the tractor, and normally he's happy to tell me "don't do that" if my ideas are insane. Still, you really need to match the bucket to the use. I wouldn't attempt to do any digging or heavy materials in the big bucket, for me it's leaves and branches and light crap. Thing big 750 lb metal replacement for a tarp. Otherwise I'll be using my heavy duty bucket that is the width of the tractor.
I'll relay my experiences on this somewhere if/when I get the huge bucket. I think I'm going to pull the trigger on this:
Because (a) it's available (though was on backorder until recently), and (b), it's cheap for the size and (c) I really want that 49 inch depth, though that will further challenge the lift capacity, that's way out there for a bucket. I haven't even seen any other buckets deeper than 39 inches. I know the bucket is going to look ridiculous on the tractor, but if it does what I want, great.
I'm definitely cautious, I have hilly terrain, and don't want to do anything that aggravates a tractor-tipping environment.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #8
If you're worried about width, consider the size of your barn/garage door opening. 8' could be tricky. Otherwise, if you can carry 8' logs in a grapple, why not an 8' bucket?
Another consideration, if you're using the bucket to clear snow (though buckets for clearing snow are of limited utility in some environments), 8' might be a nice width for clearing the necessary width of a driveway in one pass.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #9
You talking about this bucket?
I'm definitely interested in that MBHVX84 model, which has a struck capacity of 39+ cu ft.
Definitely different from the similar model without the 'X' in it which is smaller.
And therein is a huge dilemma in numbers. The Titan link I posted is lacking in details. By the numbers I'd expect its 40" H, 49"D, 84"W bucket to have much more capacity than the HLA model, but ... that isn't what they publish. I'll have to take their word for it. If I do the math I would have guessed the Titan model might bear near 49 cu ft. of material, but they only adversize ~35 cu ft.
Good luck, curious what you get.
I spoke to the dealer earlier this week about the HLA MBHVX84, he said it'd be $2213, plus ~250 freight to the dealer, plus additional to deliver to me, and that the availability was unclear and I might have to wait until fall (he didn't know, was just prepping me for worst case scenario).
The titan is $1699 delivered, but of course Titan Attachments has a reputation much discussed here. In fact I spent the morning going through ebay feedback on them for their buckets. It sounds like most issues that I was worried about (correctness of SSQA fit) have improved since people complained about it 7-8 years ago. Still a risk though.
   / How big a bucket can I put on a Kubota M5040 with LA1153 loader? #10
I have a 78" HLA bucket with bolt on cutting edge on an LA1153E
Works perfect, 72" is too narrow for me.
Chariot 12' Box Trailer (A59814)
Chariot 12' Box...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
John Deere 5055E (A53317)
John Deere 5055E...
