How bad did I mess it up YM2200
   / How bad did I mess it up YM2200 #1
jbone108
I'll try to keep this short.
Decided to start up the tractor today and run the disc over the garden sense the tractor had not been run in a couple of months due to winter.
heres what happened. tractor was run with no water in radiator/motor for no more then 10 min temp never got over normal running temp on guage "due to freeze plug popping out sometime this winter" the motor had a sudden loss of power then died also blow a puff of smoke out of PCV "i think anyway" it's the valve on top of the valve cover with a hose running off of it down to the below the starter. it also blew some oil out from around the valve cover gasket.
I was able to restart the motor and it came up to rpm and sound fine and ran fine. but it is still blowing gray smoke from the PCV tube. I pulled the valve cover all looked ok.
what do I need to do next? I know the first thing I need to do is replace the freeze plug. Is it ok to reuse the same freeze plug?
thanks for any input/help
   / How bad did I mess it up YM2200 #2
It's not a good thing to run hot. You may have gotten lucky. I would install a new freeze plug fill with the correct amount of anti freeze run the tractor & see what happens. If you did any damage you will know it .
   / How bad did I mess it up YM2200 #3
In addition to what kenmac said, I would also change the oil. Probably the reason the gauge did not show hot was that there was never any coolant in contact with the sensor to heat it up.
   / How bad did I mess it up YM2200 #4
Sounds like you my have gotten lucky. I would definitely change the oil like normde says. And use a new freeze plug. Then fill it up with antifreeze mix and go to it.
   / How bad did I mess it up YM2200 #5
Finally able to see someone else out there besides me for a change that has a YM2200. I had mine given to me after my in law used the tractor with no water in radiator. He assumed it was useless. I then dug into it after chatting with some folk on here. Extra thanks to Mark777 with the instant message support..When I had got my yanmar it would start but had very low power and white smoke out the exhaust. Come to find out it was running off one of two cylinders. I then pulled the head and saw that it had a cracked head which leaked water into the one cylinder. I took the head to get repaired to a place called Mosley Machine Shop in downtown Houston and they did a very good job on making this head look brand new for 350.00. I then put it back together and so far not anything has gone wrong with that. I am not sure why oil would come out the pvc thingy since I didnt have that problem nor did I even know they had freeze plugs. Let us know what you do to get this problem fixxed since I just may have that problem one day with mine..Good luck
   / How bad did I mess it up YM2200 #6
The gauge cannot register proper temp without direct contact with coolant. A gauge not registering hot on an empty cooling system means nothing. Sorry.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
Ran during check in. No longer running. (A51694)
Ran during check...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
