How agriculture works thread
   / How agriculture works thread #1,023
Grain dust is very explosive, it is much less frequent then is used to be.
   / How agriculture works thread #1,025
Some of dad's slides of upgrading from a old tile silo to a poured silo. There are not many silo's that are completely poured. Most have a metal chute as I imagine was a cost savings then. I have been up metal chuted silo's and when they rust out snag you endlessly as you climb them. Not an issue with cement chutes. One of the cost savings grandpa did was no protective cage on the silo. Another thing we had I have never seen elsewhere was an electric distributor for filling. Most fill pipes have fins that distribute the silage as it fills where ours would rotate throwing the silage against the outer wall creating an inverted cone and fill the silo evenly.
   / How agriculture works thread #1,026
The build
I'm sure dad was not impressed when he got the roll developed.
View from the silo.
And yes every year carried a 100 ft extension cord for the distributor. Silo was a 20x60
   / How agriculture works thread #1,027
Our old wooden silos had a flexible pipe at the end of the blower gooseneck that could be adjusted while filling. Once we went to the concrete stave silos they all had the electric rotating pans for distributors. Our wood stave silos had wooded chutes up the outside for access when unloading, the concrete stave silos had galvanized metal chutes for the silage to come down and people to access the silos. We also had/have the steel ladders up the outside to the top.
   / How agriculture works thread #1,028
Even our stave silo is a concrete chute. Maybe it was also how that particular company put them up. Or it was an option. To young to know. Lots of questions would love to ask my dad now that I'm older.
Most in the area we lived in were block style like these. The 2nd most common were the harvestor made steel ones.
   / How agriculture works thread #1,030
There’s a few harvestore around here. Here’s a today view of the silos
There’s a few harvestore around here. Here’s a today view of the silos View attachment 3886543
Those concrete Harvestor would be new to me.
Harvestore is a brand of agricultural silos known for their oxygen-limiting technology, primarily used for storing high-moisture forages and grains like haylage and high-moisture corn. They are constructed with glass-fused-to-steel, which provides a durable and corrosion-resistant storage environment. Harvestore silos are designed to minimize spoilage and dry matter loss, resulting in high-quality feed for livestock.
   / How agriculture works thread #1,032
Harvestore is a brand of agricultural silos known for their oxygen-limiting technology, primarily used for storing high-moisture forages and grains like haylage and high-moisture corn. They are constructed with glass-fused-to-steel, which provides a durable and corrosion-resistant storage environment. Harvestore silos are designed to minimize spoilage and dry matter loss, resulting in high-quality feed for livestock. View attachment 3886561
No. Those are our silos. No longer used.
Correct. Harvester silos are metal with their trademark blue. There are a couple in the area here. Bottom unloading which is neat. Sealed top. Never have dealt with them.
   / How agriculture works thread #1,033
Weren't they used mostly on dairy farms?
   / How agriculture works thread #1,034
Yes though I’m sure there were and are beef operations that still use them. I would like to use ours but would require refurbishing one of many reasons not used.
Most operations have gone to bunks/bags for silage storage.
   / How agriculture works thread #1,035
The harvester silos made good feed when good feed was put in them, the unloaders were a nightmare. When one screwed up it was often several hours worth of work to get it out of the silo to repair.
   / How agriculture works thread #1,036
Silos, on the farm.
1918, newly poured concrete
1908, 12hp hit miss engine, ensiler and elevator, and brand new brick silo. There are finger prints on the bricks from before they were dried or fired, two layers thick, wired with barb wire anchors, lined with coal tar and lime mortar.
Similar 12hp hit miss engine:
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2011 Freightliner Cascadia 113 S/A Day Cab Truck Tractor (A59230)
2011 Freightliner...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
JLG 600 AJ SKYPOWER BOOM LIFT (A60429)
JLG 600 AJ...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
