How agriculture works thread
/ How agriculture works thread
In ND this week. I'd guess central or the westerm part.
/ How agriculture works thread #1,042
Some of this farms in ND must be huge. I mean a mile or two before you turn around at the end of the row.
My sis's farm just lost this tractor and air seeder to a fire. I have no pics, so I found these of the same machines on the web. They do have them insured.
/ How agriculture works thread #1,046
That 9 Series JD and planter is a staggering cost. Was it a grass fire that got out of control or something with the equipment?
It was in there machinery yard and thought it was an electrical fire.
You peaked my interest so had to look up its specs.
Weight is around 38,600 pounds (17,508 kg) when equipped with 480/80R46 triple tires, while its shipping weight (without fluids) can be around 35,530 pounds (16,116 kg).
Specifications​
Engine​
Number Of Cylinders​
6
Engine Make​
2240
Engine Model​
PowerTech Plus
Gross Power​
425hp
Pto Power​
320hp
Power Measured @​
2100rpm
Displacement​
823.9cu in
Torque Rise​
38%
Aspiration​
turbocharged, air-to-air aftercooling
Operational​
Fuel Capacity​
350.1gal
Hydraulic System Fluid Capacity​
28.1gal
Cooling System Fluid Capacity​
14.1gal
Engine Oil Capacity​
11gal
3 Point Hitch Type​
4N/3, 4/4N
Turning Radius​
14.6ft in
Operating Voltage​
12V
Alternator Supplied Amperage​
200amps
Transmission​
Transmission Type​
24-speed Powr-sync
Number Of Forward Gears​
24
Number Of Reverse Gears​
6
Hydraulic System​
Pump Flow Capacity​
48.1gal/min
Axles​
Final Drive​
Inboard Planetary
Axle Length​
119.9in
Axle Diameter​
4.4in
Hydraulic System​
Relief Valve Pressure​
2900psi
Number Of Remote Control Valves​
4
My sis just told me they'll look for a used replacement tractor and try repair the damage to the air planter. I'll try get pics.
/ How agriculture works thread #1,051
That is sad. Hopefully have good coverage.
Laura Farm's finally made a reasonably good video and this one is about the cost of farming. I had quit watching her video's.
/ How agriculture works thread #1,054
How to get your X-9 sized combine off the road and into a corn field.
Even people who think they know would be shocked at the price of all the equipment in that video.
Also worth mention is the extra effort the combine operator went through so he didn't miss even ONE ear of corn at the start of the row. :)
/ How agriculture works thread #1,055
Not shocked so much as dismayed at the extreme cost of modern large equipment.
/ How agriculture works thread #1,056
I am in the middle of trying to buy a 10-15 year old 175-200HP farm tractor and cannot believe the cost.
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 Kubota RVX900 4x4 Diesel Utility Cart (A59228)
2020 Kubota RVX900...
2015 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2015 Nissan...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
