How agriculture works thread
   / How agriculture works thread
In ND this week. I'd guess central or the westerm part.
   / How agriculture works thread #1,042
Some of this farms in ND must be huge. I mean a mile or two before you turn around at the end of the row.
My sis's farm just lost this tractor and air seeder to a fire. I have no pics, so I found these of the same machines on the web. They do have them insured.
   / How agriculture works thread #1,046
That 9 Series JD and planter is a staggering cost. Was it a grass fire that got out of control or something with the equipment?
It was in there machinery yard and thought it was an electrical fire.
You peaked my interest so had to look up its specs.
Weight is around 38,600 pounds (17,508 kg) when equipped with 480/80R46 triple tires, while its shipping weight (without fluids) can be around 35,530 pounds (16,116 kg).
Specifications​
Engine​
Number Of Cylinders​
6
Engine Make​
2240
Engine Model​
PowerTech Plus
Gross Power​
425hp
Pto Power​
320hp
Power Measured @​
2100rpm
Displacement​
823.9cu in
Torque Rise​
38%
Aspiration​
turbocharged, air-to-air aftercooling
Operational​
Fuel Capacity​
350.1gal
Hydraulic System Fluid Capacity​
28.1gal
Cooling System Fluid Capacity​
14.1gal
Engine Oil Capacity​
11gal
3 Point Hitch Type​
4N/3, 4/4N
Turning Radius​
14.6ft in
Operating Voltage​
12V
Alternator Supplied Amperage​
200amps
Transmission​
Transmission Type​
24-speed Powr-sync
Number Of Forward Gears​
24
Number Of Reverse Gears​
6
Hydraulic System​
Pump Flow Capacity​
48.1gal/min
Axles​
Final Drive​
Inboard Planetary
Axle Length​
119.9in
Axle Diameter​
4.4in
Hydraulic System​
Relief Valve Pressure​
2900psi
Number Of Remote Control Valves​
4
My sis just told me they'll look for a used replacement tractor and try repair the damage to the air planter. I'll try get pics.
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
Arctic Cat 650 w/Plow & Sprayer (A55272)
Arctic Cat 650...
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
2-5TH WHEEL PLATES (A58216)
2-5TH WHEEL PLATES...
2004 PETERBILT 379 (A58214)
2004 PETERBILT 379...
