House II
/ House II #81
Re: House II, Porch Siding
It doesn't look too bad, but it was real scary at the time. Anyway here is my front porch framed up with the porch roof framed too.
/ House II #82
Here is a good side shot with garage.
/ House II #83
Of course what is a job site without a good workhorse to get things up in the air.
/ House II
Gotta love that equipment, eh! Bummer about your truck, I know what you mean about a rental etc. It's just not right. House looks to be coming along nicely.
We had a good meeting with the builder last night. Pinned down the costs and timing pretty well. The drywall finishers are supposed to be done this week with first coat of paint early next week so we'll be in there late next week with our ceramic tile project.
The lift arrived yesterday for the siders so they're working on the higher areas now. Camera batteries died, so more pics tonight /w3tcompact/icons/smile.gif
/ House II #85
Hey Patrickg,
Sounds really fun! Who is doing your soils/basement engineering? I hope to do the same thing 2-3yrs except probably not a walkout. I thought you were thinking about totally underground? I like the thought of the heating/cooling/tornado issues but want to "see" the house. How about a safe room in the corner somewhere?
My thoughts at this minute are regular poured walls for basement and ICF's for the above ground walls. I know the ICF guys say go all the way from footing to roof with the ICFs but nobody has any fool proof ways to keep termites out of the foam. My solution is to not put foam in the ground. I know Ill lose some BTUs thru the exposed wall especially above grade, but what a nightmare it would be to try to get termites out of the foam wall. Could/would insulate wall to within a few inches of grade, leave exposed wall for inspection purposes and continue with ICFs.
Keep us updated!
I will have to come see you once you get underway.
Gary
/ House II #86
Chillimau, The soils engineer that was recommended to me by the civil eng who did the foundation design on my mom's house is Arvel Williams. The civil said he likes this guys work and feels comfortable with his jobs. I'm not sure he would want his number on the WWW but I can give it to you privately if you want it (just say).
I really like the walk out idea as does my wife. The house will look like a three story from the south and a two story from other directions. Yeah, I backed off the earth sheltered house. By my analysis, there isn't enough gain in energy efficiency going earth sheltered to warrant losing the view we have available. I have not lost "faith" in earth sheltered designs with 3-5 ft of earth cover on top and spent about 7 years studying and preparing on the topic. Part of the motivation for earth sheltered housing is living at ground zero in tornado alley. Another big part was efficiency.
Well, as they say, once you get a house so tight and insulated that you can heat it with a candle and cool it with an ice cube there just isn't enough budget in HVAC to warrant getting too exotic. My mom's house is averaging about $50 month (all electric). I set the thermostat and let the heat pump do its thing day and night and June's electric bill was $49.xx. Last winter we used 300 gal of propane in the gas log AND some electric heat (heatpump). I expect my house to be more efficient that hers and although larger, not more expensive to heat and cool.
How much can you reasonably spend on energy efficient systems to try to save a slice of the $50/month. For example, let say you could buy a system that would heat and cool the house and use only 1 penny's worth of electricity for the year. Given our average bill of $50/month that would save us $599/yr. If that MIRACLE SYSTEM cost say $11,990 then what would the payback time be? A hair over 20 years! IF it were a $6000 system it would pay for itself in energy savings in 10 years. But lets get real, systems don't run on imagination they use KWh and can be quite expensive (price a ground based heatpump). If the breakeven period for an energy efficiency upgrade is a longer period of time that either your life expectancy or the life expectancy of the system then it is not such a good investment.
Safe room, you say? Our master suite and one guest bedroom will be safe rooms with all ceilings, floors, and walls, interior and exterior, for those rooms, a minimum of 8 inches of steel reinforced concrete. One of the contractors who will bid the job does regular poured walls but would have to be a real bargain to compete with ICFs since the ICFs provide insulation and have "nailer" strips every 6 inches so no fir out is required.
Yes termites can tunnel through EPS but don't eat it. There are some excellent anti-termite applications that will prevent termites from getting to the EPS. My "jury" is still out but I haven't ruled out ICFs all the way from foundation to first floor plate. Our victorian style will probably not have perimenter walls in the upstairs, so no ICFs above the first floor. Upstairs will be about 1/2-3/4 the floor space of the basement or ground floor in attic rooms with dormers.
Of course there will be more to see after we get further along but for a free cold soda and chat, drop by anytime you can catch me. I'm here much more that I am gone. If there is an open door at the shop, I am probably doing something there. Otherwise probably at my mom's or tractoring. That said, I'm going to take my truck and tractor in to Ada tomorrow afternoon. In the morning a local dirt guy is taking a look at my site in prep for some bids.
Patrick
/ House II
Re: House II, Porch Ceiling
Here's a shot of my very own handiwork on the new house. This is the porch ceiling finished off with beadboard plywood. It still needs a finish coat of traditional sky blue paint and some trim around the edges but it's beginning to take shape. Wife helped too, so I can't take all the credit /w3tcompact/icons/smile.gif
/ House II
... and a more up to date shot of the whole house including the lift the siding guys are using for the high peaks. Nice weather is keeping things moving along for us /w3tcompact/icons/smile.gif
/ House II #89
RobS,
That is one great shot. I stopped out today and they have the plywood on the garage roof done. So I now realize it takes a while to put that stuff up. I guess they will be done with that by end of next week or so. The roofers will be right behind. Lots of work to do and about 2 months or so to go, but man it seems like it will never get done.
I will take pics this weekend and update. Nice green stuff you got there too.
/ House II #90
Great looking house!!!!
/ House II
Re: House II, Porch Footings
Totally fun day today. Got to dig the porch footings and as luck would have it our builder has a 4200 with a Woods backhoe /w3tcompact/icons/grin.gif Here's a shot of Jeff the builder hard at work but the best part is that we popped a fitting /w3tcompact/icons/crazy.gif It was the best part 'cause Jeff left me to get the new fitting and finish the job while he headed off to the lake with his family /w3tcompact/icons/smile.gif
/ House II
I know it's hard to see past the grin on my face, but that's a backhoe in my hands /w3tcompact/icons/grin.gif Dug six of the eight footings. I'll finish the other two tomorrow as the siding guys were working in that area. Now to convince my wife I need one of these things /w3tcompact/icons/smile.gif
/ House II #93
Robs,
Now that picture shows a man on a mission, then again, it shows someone having waaaaayyyyyyy to much fun. But heck a CUT is perfect for snow removal, landscaping stuff mover etc. Your wife should let you get one right away (after you move in.)
/ House II #94
Okay, here's the updated pics. The roof is just about capped with plywood. They have a small area on the main roof to do and then the hand framing of the turrett beings, plywood etc and the porch roof and gable too.
Here's the front with the fork lift.
/ House II #95
Here is the side.
/ House II #96
The back yard and garage.
/ House II #97
Driveway side and all of our roofing materials are ready to go. I figure end of next week begining of the following week for the roofers.
/ House II #98
OK. Now I've got to ask, why do they put the footing in after they build the porch? I've seen it done this way all over and I don't know why? Why isn't the footing poured first?
Way too much fun there!
/ House II #99
Easy! Footers=backhoe=FUN!!!
/ House II #100
Mossroad,
Good question? Our footers were poured before they did any major framing of the porch. So I am wondering too?
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
(12) John Deere 1.5bu. seed boxes for JD 7200 planter, Taylor Ridge, IL (A65640)
(12) John Deere...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
2017 International 4300 Box Truck (A62613)
2017 International...
