Hour meter stopped working
/ Hour meter stopped working #2
Check your fuses. Tractorsmart.com can send you a wiring diagram. On a BX2200 the hour meter, lights and fuel pump are all fed from the same fuse.
The engine is running fine & the lights also. So will have to assume the problem is mechanical (gauge itself) or electrical... /forums/images/graemlins/confused.gif
/ Hour meter stopped working #4
Some last a long time, some don't. Kubota doesn't make 'em.
With a test light, see if the meter is getting power. If it is, the meter needs to be replaced. They are generic, you can find them on the internet for about $10.
/ Hour meter stopped working #5
The wiring diagram is free so it would be worthwhile to have for future reference and to see which fuse actually feeds the meter. My BX will still run with the fuse blown. The fuse also feeds the troublesome fuel gauge circuit on the BX2200. When the fuel leaks around the sending unit it cuases the circuit to short and blow the fuse. I'm sure that doesn't happen on the newer BX23. Checking fuses is still the first and easiest step to solving your problem.
1993 Chevrolet Corvette Coupe (A64557)
1993 Chevrolet...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2017 Gravely ZT-X 52in Zero Turn Commercial Mower (A64194)
2017 Gravely ZT-X...
2015 Chevrolet Tahoe SUV (A64557)
2015 Chevrolet...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
