Hour meter stopped working
/ Hour meter stopped working #2
Check your fuses. Tractorsmart.com can send you a wiring diagram. On a BX2200 the hour meter, lights and fuel pump are all fed from the same fuse.
The engine is running fine & the lights also. So will have to assume the problem is mechanical (gauge itself) or electrical... /forums/images/graemlins/confused.gif
/ Hour meter stopped working #4
Some last a long time, some don't. Kubota doesn't make 'em.
With a test light, see if the meter is getting power. If it is, the meter needs to be replaced. They are generic, you can find them on the internet for about $10.
/ Hour meter stopped working #5
The wiring diagram is free so it would be worthwhile to have for future reference and to see which fuse actually feeds the meter. My BX will still run with the fuse blown. The fuse also feeds the troublesome fuel gauge circuit on the BX2200. When the fuel leaks around the sending unit it cuases the circuit to short and blow the fuse. I'm sure that doesn't happen on the newer BX23. Checking fuses is still the first and easiest step to solving your problem.
MASSEY FERGUSON 4710 TRACTOR (A64280)
MASSEY FERGUSON...
EXCAVATOR TEETH, HYD CYLINDERS, ETC. (A63291)
EXCAVATOR TEETH...
2013 29ft. Larson LXI292 Boat with 30ft T/A Loadmaster Boat Trailer (A61574)
2013 29ft. Larson...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59912)
2011 GREAT DANE...
