Hour Meter Issue
/ Hour Meter Issue #1
sycamore
Bismarck, ND
Kioti NX6010; Kubota B3200; Ford 9N; John Deere X360
I have a 2012 Kubota MX5100. Last summer, while it was still under warranty but right near the end of the warranty period, I was running a few fairly long days doing some disking for mid contract management on CRP. I noticed the hour meter was not registering correctly. For example, I would have the tractor engine running for 8 hrs. and the meter would show 6.4. I checked it 2-3 times and it underreported about the same each time. On Aug 22, 2014 I sent an email to my sales guy alerting him to the problem and included the following: "But just wanted to flag this during the warranty period, which according to the post card I got ends on 8/28." I heard nothing. I sent another email around the end of the warranty period; nothing. Then I called. Yes, they had gotten the email but a work order had to be started in the shop (which apparently hadn't been done) and the warranty period was now over. And I was told that Kubota was really tough on this type of thing and there just wasn't much they could do. Really?
So, two questions.
First, is this how a dealer should handle a warranty issue? What has been the experience of others? Did I error in not making a bigger deal of it or showing up at the dealership stressing the urgency? I guess I expect a dealer to protect my interests, but maybe that is not typical? I also talked to the head guy in the shop about this hour meter issue when I picked up my B3200 from warranty work; this was in late August 2014. He had seen my email. He was going to check on things and give me a call that day or the next. It is now Jan. 13, 2015 and I am still waiting for my call. Not impressed.
And second, how should an hour meter function? I grew up on tractors and farm equipment and thought I knew. I always thought an hour meter recorded the length of time an engine was running. But I got some very confusing information in the process of talking to my Kubota dealership and calling around to some other implement dealers. I was told the hour meter might or might not record all the engine hours, with lots of mumbo jumbo reasons that made no sense to me. In reality, no one really seemed to be sure. So what is the story on what an hour meter is supposed to record?
Thanks much.
/ Hour Meter Issue #2
Some hour meters are measured at PTO speed.
/ Hour Meter Issue #3
Like above post, most tractors measure low idle time and running at high idle [ PTO speed ] different. Basic hour meters that just run off 12volts usually just keep track of time. My Mahindra gets it's hour meter pulses from the alternator, which somehow lets it know if I am actually working or just sitting there picking my nose... :)
So, there is probably absolutly nothing wrong with your hour meter... Don't Worry.. Be Happy.. !!!!
/ Hour Meter Issue #4
murphy 1244 is correct. my previous mx5000 series (assume yours is the same?) tach/hr meter ran mechanically off a cable. the system was designed to register hours @ engine rpm @ 540 pto delivery. depending on tractor model, this ranges from 2100 rpm or greater. so if you're idling @ say 1100 rpm, it will register less on the hr meter than actual time of engine running if that makes sense. where this comes into play is either your scheduled maintenance or purchasing a rental tractor that may have more actual clock hrs on the engine than the meter has recorded. sorry for confusing explanation, but that's my experience with my previous mx5000. you can always check it by a stop watch when you start your tractor, and compare it to your rpm/pto output @ 540 again, sorry for lengthy explanation of something simple :)
/ Hour Meter Issue #5
There is nothing wrong with the meter -- it's RPM based. Not sure exactly what RPM gets you to the point where tractor hours = wall clock hours (on many tractors it's rpm needed for 540 at PTO), but you should not expect 8 wall clock hours of "variable RPM" use to show 8 tractor hours on the meter. That's not how they work on Kubota diesels.
/ Hour Meter Issue #6
it depends if tach is mechanical (cable/ pto related) or electronic. so either the tractor model is engine pto/rpm related (mechanical) or turn on the ign swithch (electronic). my mx5000 was mechanical, my 8540 is electronic. that's all.
/ Hour Meter Issue #7
Here's my take on this,, "excluding the 12 volt timers",
At idle, your meter will turn slower (slower rpm's) so one hour of real time may only be 1/2 hr on the meter. Bring the rpm's up to pto speed, this increases the speed also of the timer, so now a 1 hour real time will be closer to 1 hour meter time.
So when you see a tractor with 2000 hrs on it, it could have 3000 hours of "easy" actual real time, or it could have 2000 hours of "hard" high pto speed real time.:confused2:
/ Hour Meter Issue #8
exactly :)
/ Hour Meter Issue #9
I wasn't aware that some hour meters worked this way...Surprised that the dealer wouldn't know this however...You sure you want to let them work on your tractor?
/ Hour Meter Issue #10
Like the others have said, depends on the hour meter type.
Some of the electronic meters read clock hours.
I have had 2 tractors and both have been RPM based meters. 1 hour at/near PTO engine speed will read 1 hour on the meter. Running the engine below PTO speeds and the meter will clock hours slower.
YANMAR XIO35-6A EXCAVATOR (A59823)
YANMAR XIO35-6A...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
2007 Yamaha Rhino 660 (A61307)
2007 Yamaha Rhino...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
