Hour meter install
/ Hour meter install #1
AHNC
Nevada City CA
Kubota BX 2660 & BX-23
My 2660 dash conked out so I have lost hour meter and rpm. They want about $450 for a new dash and while I love the machine I think I will just install an hour meter to keep up with service times. Fuel gauge is unreliable, but temp gauge works...for now! Much obliged for any alternatives/recommendations you can suggest. What am I missing?
My BX23 has the analog hour meter. Electronics are great, but...!
/ Hour meter install #3
Are you sure the demise of your dash killed your tach and hour meter? On many tractors (even some newer ones) the tach drives off a cable from the engine or alternator. Check to make sure you haven't just lost the cable. It's like the old speedometer cables - same principle.
Actually, Roadworthy, no I am not. I just cannot read the digital display which indicated to me that it is shot. Any suggestions? Perhaps I can just replace the display? I will check and see if it is offered as a part.
/ Hour meter install #5
Maybe you can get it repaired? Some companies are able to repair dashes.
/ Hour meter install #6
I had an old bx2200 that had no tack. I added a small tack that tied to the number one injector pipe. If memory serves, the cost was minimal. That plus an hour meter might keep your costs down.
Sorry I don’t remember cost or where I got it.
I will look into this a bit further. The "brains" of the unit must be a chip somewhere and the problem is likely...hopefully, the segmented display. Now to find the same size display. I am out of my league on this, but...onward through the fog!
429668 (A61166)
429668 (A61166)
Kubota SVL 95-2S Track Skid Steer (A61166)
Kubota SVL 95-2S...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2014 Infiniti QX60 SUV (A61569)
2014 Infiniti QX60...
2010 Ford Mustang Sedan (A61569)
2010 Ford Mustang...
