Hour meter adjustment
/ Hour meter adjustment #21
I got a cable drive Tach with built in hour meter and it sucks. The tach needle bounces so much you cant hardly read it. And the slower the engine runs, the slower the hours read so its not even close to accurate.
/ Hour meter adjustment #22
my hour is all screwed up, it supposed to be aroung 400. It reads over 6000, Meter must of gone bizerk.
/ Hour meter adjustment #23
Never done it But it would make sense that if the hour meter is controlled by an electronic chip .. that the chip would have a reset or clear leg. need to find out if it is cleared by applying a voltage or grounding a pin?
Has anybody looked up the pin configuration for the timer chip?
Just a thought
/ Hour meter adjustment #24
You can buy 12 volt hour meters and wire them up so they work when the engine in running. Some tractor manufactures do not use the hour meter as a normal clock. They don't count the time you are running around idle RPM's the same as near PTO speed RPM's. That may be why yours looks to be wrong, but really may be working as designed. You could try pulling your cable out and greasing it. Used to have to do this many years ago when all vehicles had cable driven speedometers.
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
Kubota Snow plow with subframe
Kubota Snow plow...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
