Hotrod Yanmar
/ Hotrod Yanmar #1
FlashPoint
Texas
Yanmar 1401D 4x4
Got the dash gauges installed , I used pods i had left over from another project , They worked out great and are in a good location to veiw easy. I got a little carried away and added diamond plate below the dash because most of my sheet metal is rusted badly.
/ Hotrod Yanmar #2
Looks great, and the restore is coming along nicely. If that is the original steering wheel, what did you use on it? BTW, if you would put the whole restoration project on the same thread it would be easier to follow, and greatly appreciated by all. On this forum, each new post brings your thread back to the top.
/ Hotrod Yanmar #3
Norm
You can restore your steering wheel by scraping off the white powder with a knife and lightly go over it with a propane torch.
You can do it without scraping it but it works better if you do.
Mike
/ Hotrod Yanmar
Norm ,
The steering wheel is new from Fredricks. old one was messed up bad.
/ Hotrod Yanmar #5
I'm working on adding gauges to our 1510D but didn't want to use pods. Will the pods on the cowling get in the way when you add fuel?
cvt
/ Hotrod Yanmar #6
Here is a pic of how I ended up mounting the gauges on my 186D. They are very visible on or off the tractor! They are also lit so you can easily read them in low light.<font color="black"> </font>
/ Hotrod Yanmar #7
are these gauges elec. or mech. gauges? If they are mech. where did you get the metric adapters that screw into the water temp. & oil pressure slots?
/ Hotrod Yanmar
There mechanical , Autozone has the Sunpro kit to adapt to metric. The kit didnt have one for the water temp but had a adapter that would screw in the hole above the water pump. So i drilled the center out to make it fit and J-B welded the gauge sender in place, Keep in mind when you install the sender the lead needs to turn with the sender as to not twist off or kink the tube inside.
/ Hotrod Yanmar #9
Flashpoint,
Autozone is where I got mine. The adapter for the water temp gauge comes seperate from the one for the oil. I don't have the part numbers, but it sounds like you took care of it. I trust my gauges more than some idiot light.
/ Hotrod Yanmar #10
RobF,
Great looking install on the gauges. I may just copy that outright if I ever get around to installing the Sunpro gauges I bought on my 186D. Yours is much nicer looking than mine and you have the old style power shift on the tranny just like mine. Did you fab the mount or source it somewhere?
Jeff
/ Hotrod Yanmar
Ok heres the latest of my mods. I made a new exhaust using a TSC 8N ford muffler and routed it down away from me making less noise and smoke in my face also ive replaced the muffler 2 times from hanging it on tree limbs. I used seemless pipe joints used to build fence and hand rails.Checked all the clearances and its still just tacked until loader is in place.But it sounds really good. and is quite.
/ Hotrod Yanmar
I also had a envy for the bigger tractors that had a toolbox mounted on the tranny under the seat area . So i looked around all my junk and found a ammo can pulled out the plasma cutter and chopped the top off. I drilled small holes and screwed it down. I also drilled two small holes for drains just in case it rains or i spill my beer. I gave the last of my edging away to a friend but autozone has door edging that will work nice so there are no sharp edges. This project could also be done easy with a sawall or a grinder with cutting blade.
/ Hotrod Yanmar
Heres a pic of the loader i received Free of charge from a friend .Im not sure what it came off of but for free it was a bargain. The hoses are all split and the control is stuck so ive started a list for the parts i will need. I sand blasted it yesterday and painted i am in the process of building the brackets at this point. More pics soon.
/ Hotrod Yanmar #14
Looks like everything is coming along nicely, keep us posted!
/ Hotrod Yanmar #15
Very cool project.
Don't spill your beer. That would be very bad.
/forums/images/graemlins/wink.gif
/ Hotrod Yanmar #16
</font><font color="blue" class="small">( Very cool project.
/forums/images/graemlins/wink.gif )</font>
Heck yeah, that's alcohol abuse! /forums/images/graemlins/grin.gif
Cool project, keep us posted!
/ Hotrod Yanmar #17
Thanks Jeff,
Yes, I had to make the gauge mount from scratch. I made up the wire loom with a six pin plug (Radio Shack) so if I ever need to remove the panel from the dash it will easily unplug. I had painted the tractor this last summer!
Rob
Sellick S80 (A60462)
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2005 CLUB CAR CARRYALL UTV (A64280)
2005 CLUB CAR...
2014 Takeuchi TS50R Compact Wheel Loader Skid Steer (A61572)
2014 Takeuchi...
Takeuchi TB225 (A62177)
Takeuchi TB225...
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
