Hot water tank.....question
   / Hot water tank.....question #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
I noticed this evening the hot water at the faucets is much hotter than normal. Last time I adjusted the T-stat was probably a year ago and I checked to make sure they were still set where I had them.....they were. I have the T-stat set at approximately 140 degrees.....main purpose is for the dishwasher. I just took a temp reading from the faucet....its 160 degrees. Whats going on here....T-stat not working right or the heating element(s)?
   / Hot water tank.....question #2
Electric hot water heater, oil , or gas?
I'm suspecting electric. But I'd try turning the T-stat down and see if the temp of the water drops accordingly.
Sorry, electric. I turned the T-stat down, I guess we'll what happens.
   / Hot water tank.....question #4
One possibility is buildup in the tank either as sediment or crust. Do you have soft or hard water?
   / Hot water tank.....question #5
I'm building a stove, 4th one, out of a hot water tank. This tank was gas, but the first 3 were electric. All the tanks had a lot of build up on the sensors and / or heating elements. This last tank was the worst. There was at least a bucket (2.5 gallons) of sand and minerals in it. One of the sensors was a just a huge blob. There was really nothing wrong with the tank other than the crude inside.
I recently changed a heating element on another tank, same thing, build up of minerals.
If about once a year folks would open the drain valve on the tank and let it flush out the crud the tanks would last a lot longer. But don't try that on an old tank, as it may never shut off or work right again.:(
I would say the water is more on the hard side but not to bad. I would think to much build up or sediment would cause it not to heat sufficiently (not enough). Just out of the blue, its heating to much.
   / Hot water tank.....question #7
Build up on the heating element will slow down heating. Build up on the temp. sensor is like insulation so it takes it longer to feel the heat in the tank.
So a possibility is build up on the T-stat and as the water continues to heat the T-stat is not registering it? and water temp continues to rise? So far it hasn't tripped the high limit switch.
   / Hot water tank.....question #9
The T Stat is on the outside of the tank on most electric water heaters not in the water stream and are known to be not very accurate.. Make sure you turn down "both" T Stats the same amount..
   / Hot water tank.....question #10
The top t- stat controls the time/temp the top element heats ,the bottom t-stat controls the bottom element heat but will not heat as long as the TOP.needs to run to SATISFY its temperature.,because you draw water off the top . You can amp probe the elements about 15-17 amps depending on element watts. You must satisfy the top t-stat temp ,to get the voltage to switch to the bottom t-stat to amp probe it.adjust setting to turn on/off element. I always use the clip over wire amp probe, both amp readings should be the same when heating. weird reading ,bad element.
bottom element usually is the bad one. in your case sounds like the top t stat bad.
make sure the top element has heated enough to switched voltage to the bottom element and the t-stat calls for heat on the bottom element to amp probe the bottom element. there should be power to the bottom element to amp probe it.
be safe just my way of doing it.
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
