Hot hydraulic fluid + loss of cylinder pressure
   / Hot hydraulic fluid + loss of cylinder pressure #1
Pete in FL
I've got a 3 pt hitch log splitter running off the loader control valve system on a B7510 Kubota. Been working fine for several years. This year after about an hour I noticed the hoses are real hot and the cylinder's lost both speed and power. FEL works fine. Fluid level is normal. Any thoughts would be greatly appreciated.
   / Hot hydraulic fluid + loss of cylinder pressure #2
Check cyl seals for bypassing, and check the return filter.
Put a hyd gage in the IN port and check the pressure.
2017 Ram 5500 Chassis Crew Cab Reading Service Truck (A52377)
2017 Ram 5500...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
UNUSED FUTURE CG34 - 34" HYD CLAMP GRABBER (A51248)
UNUSED FUTURE CG34...
