Hose size?
/ Hose size? #1
galaxie428
Rushville, IN
Bobcat CT230
I am in the process of buying a Woods BH80X backhoe for my CT230 that I will run off my rear remotes and I am not sure what size (dia) of hose I need. I was looking on Agrisupply and they have 1/2" and 3/8" hose. Here is a link to an example of both. Which one do I need or will neither one work? I am not sure what it means by 2 wire hydraulic hose.
60 LONG X 1/2 HYDRAULIC HOSE W/ONE SWI - Agri Supply
42 LONG X 3/8 HYDRAULIC HOSE W/ONE SWI - Agri Supply
Any help or advice would be appreciated.
/ Hose size? #2
I dout either will work to small i would say 5/8 or 3/4 but i may be wrong. the 2 wire is just the strenght of the hose which a 2 wire brade would be a strong hyd hose. Hope that helps.
/ Hose size? #3
Hose size is determined by the GPM rating, His machine is rated for 7.9 GPM so 5/8 or 3/4 is WAY overkill! Add to that he is running it from the rear remotes.
You will only need 3/8" hose, but 1/2" would be just a little better. 2 wire 4000 PSI rated hose is what you want.
/ Hose size? #4
The hoses on my Kioti CK30hst going to a Kioti KB2375, 7.5 foot bh, and similar to a CT230, are 1/2 inch.
/ Hose size? #5
We use 1/2
If you are going to have hoses made you will need a male 3/8 NPT on one side and a male #8 o-ring boss on the other side.
4-5' of hose is sufficiant.
If you would like you can pm me your address and I can give you a to your door price. I can even include the male end to plug into your tractor if need be.
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
UNUSED SDLANCH 25'X33' METAL SHED (A64281)
UNUSED SDLANCH...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
