Hose coupler leaking
/ Hose coupler leaking #1
waytoobusy
West Fork, AR.
Mahindra 4035
Good morning. I've looked around here and learned alot in the last year.
I have hydraulic hoses routed from my rear remotes to the loader on my tractor for using a grapple. The initial set of hoses I started with was too short to route properly under the tractor. I purchased a second set of hoses, then coupled the older hoses to the new with 3/8" female to female couplers. One set of hoses works fine. The other set (return line) leaks under pressure.
I changed the coupler, however it is still leaking under pressure.
Threads on the hoses look okay. The hose ends are 3/8" pipe and the coupler is 3/8" pipe.
Could I just have two bad couplers? Is there something I should be putting on the connections? From what I've read pipe tape should not be used in hydraulic systems.
Thanks in advance for any help.
/ Hose coupler leaking #2
If the threads are NPT, you need some kind of sealant.
Pope dope, Loctite 542. Some people still use Teflon tape if done carefully.
Pipe threads are designed to be used only a few times, then the threads are too deformed for a good seal.
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2017 Kia Cadenza Sedan (A61574)
2017 Kia Cadenza...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2023 Case TV380 (A62177)
2023 Case TV380...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
