Horse Mat for Soft Snow Blade Edge
   / Horse Mat for Soft Snow Blade Edge #31
A close-up view.
   / Horse Mat for Soft Snow Blade Edge #33
"TBNers - Keeping America CLEAN!"/w3tcompact/icons/grin.gif Thanks for picking up on the roadside.
BTW, I like what you did sandwiching the rubber between the main blade and the replaceable metal edge. I am going to TSC to get mats today and should have enough left over for my back black and FEL bucket
   / Horse Mat for Soft Snow Blade Edge #34
By the way, I used the trick of heating the 25 year old nuts with a propane torch and using birthday candles (all I had) to loosen them. Worked like a charm!!!!!!!! Even worked on the skid shoes which were REALLY rusted.
   / Horse Mat for Soft Snow Blade Edge #35
I've got to do this tomorrow. Can you explain the birthday candle thing?
Mark
Real simple, heat the nut up, stick the end of the candle on the hot nut where it meets up with the screw sticking out and let a little wax melt in. The candle wax actually penetrates between the nut & screw, and lubricates the threads for easy removal.
Works some of the time. When it doesn't, apply more heat.
   / Horse Mat for Soft Snow Blade Edge #37
Cool beans! I'll try it.
I'm going to TSC this morning to get horse mats. According to my stall measurements, I should have enough left over to put an edge on a backblade, on my FEL, and a spare. The backblade has been sitting in a muddy field for 15+ years with the cutting edge in the mud over 8 inches. If the candle thing doesnt work, I'm just going to use a cutoff wheel on my Ziptool and take the heads off.
Thanks,
Mark
   / Horse Mat for Soft Snow Blade Edge #38
When mounting the rubber on the fel, would you mount it so that when you use the bucket, its tilted down like the same as a blade?
   / Horse Mat for Soft Snow Blade Edge #39
Can any of you offer some advise now that you have one full winter of use with the horse mat edge? Would you do anything different regarding how you attached?
PJ
   / Horse Mat for Soft Snow Blade Edge #40
I had two rubber edges: one on the back blade and the other on the loader.
On the back blade, I installed it between the removable edge and the main blade like shown in the pictures. It lasted all winter and is usable this coming winter.
On the bucket, I used eight individual bolts/nuts/washers. When the snow got packed in between the mat and the bucket, it stressed and eventually tore. This year, I am brazing carriage bolts to a 6" strip of metal and using that to keep the mat on. Should work pretty well, since it will be similar to the back blade.
Wear on both mats was minimal.
Mark
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A58214)
2012 JACK COUNTY...
2007 MACK CV713 ROLL OFF TRUCK (A58017)
2007 MACK CV713...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2009 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
