Horse Barn Project
/ Horse Barn Project #1
Lloyd_E
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
This is the start of our horse barn project. Overall size is 50'x26.5'. Main part of building is 30'x26.5'. There will be two side sheds - 10'x26.5'. One will house hay and shavings until the new tractor arrives. The other shed is actually a roof over the run-in area for the horses. They will be able to run in/out of stalls at their leisure. Barn will have metal roof with light panels and board and batten siding. We will be putting two zones for radiant heat. One will be for the tack room while the other will be for remaining area - for future use. If the horses go I will have a heated workshop.
Soundguy...you can see in the background some of the fencing i have started based on discussion last year regarding preservative. I have almost 3 acres fenced with 4x4 posts/1x6x16' boards - 3 rails plus a cap rail.
Concrete will be poured this weekend or first of week. 6" slab with perimeter curbs.
Will update as we progress. I have booked two weeks (vacation - Ha!) with carpenter. We will have 90% of the barn completed. I will do the stalls in the fall along with slidng doors etc.
Image 1 & 2 shows road and site prep.
Lloyd
Day 1 Monday:
Day started at 8 and by 3 PM we had all the walls up.
10'x10' double doors gable ends, 1 ped door, 3 windows plus 2 stall doors framed. 2x6 contructions, double sill plates and double top plates.
Day 2 Tuesday: Completed walls and second floor. Will post pictures later.
Lloyd
Completion of curbs prior to starting walls.
I will be trying solar panels to heat tack room during winter months.
Lloyd
/ Horse Barn Project #5
Will be watching your progress. Looks good.
Isn't it funny the amount of work we go through just to make more work. We started with a three sided shelter and when my wife bought a foal I had to add a stall on the side. Then her Arab mare needed a stall so I got to add another. Now my wife is so busy cleaning stalls that she doesn't have time to ride and me, I don't ride.
I hope you get your own shop to play in. Its great to have a place of your own, its taken me almost 7 years but I'm almost finished mine. I think.
Hi DoubleG,
I have two other buildings to play in. One is my 12'x18' blacksmith shop. The other is 22'x28' workshop. My wife doesn't know it yet but I am willing to trade my old shop for the new building - some how I don't think it will go over!!!
I don't ride but I am interested in small work horse - Canadian or Morgan.
I have enough acreage and woods to allow the horses to work.
Thanks fo you interest.
Lloyd
Bones1,
The curbs will help preserve the walls from urin/manure. It took alot of convincing to get the builders to do this.
Will keep the pics coming.
Lloyd
We had one of the worse thunder storms last night to date (with the exception of the one that hit an oak tree in the back pasture). The following pics do not do it justice. It lasted almost 3 hours. We would just think it finally ended and it would roll back in off the bay.
Tomorrow we do board and battens, windows and man door. Friday is a day off for crew. Trusses will arrive tomorrow. When the metal roof arrives Monday we will use the boom truck to position trusses on deck. We are still aiming for mid-week, end of week finish next week with exception of sliding doors, tack room and stalls. They will be my fall and winter projects.
Light 2 shows a slight line from lightning on right side.
Enjoy the light show!
Pics from the other day. Completed second floor joists. We are using scissor trusses. Main aisle will have weight load hence the 2x6 on 12" o/c. Areas above stalls/tack room are 2x6 on 16" o/c. Joists are air nailed and are secured with metal hangers.
Lloyd
Boarding In:
Yesterday we finished boarding in and laid second story floor.
Today we are working on exterior board and batten.
We will install vertical boards and let them dry out a bit over the weekend before putting on battens.
Ped doors and windows will go in today.
Lloyd
Stopped early today due to heat. Plus we have to wait for trusses to arrive, which will be tomorrow and metal roof on Monday. We are a little bit ahead of schedule.
Pics show vertical boarding plus a few windows. Windows have to be scrapped, primed and painted and a few pieces of class to be replaced. They are recycled from a 18th century house. I will be starting to build sliding double doors on the weekend. Each door is 10'2" tall x 5'6" wide with a transom window (individual lights) 1'x4' in each door.
Lloyd
/ Horse Barn Project #12
That really looks great. You're moving right along and will have a lot more to show for your vacation time than a simple sunburn this year! So what's the plan, are you putting those scissor trusses up on kneewalls to get a little more 2nd story storage or what? Can't wait to see it sided, I used a roughsawn Hemlock B&B on a cabin refurb and love the look.
dholly,
Nop to the knee wall. Scissor trusses will sit on top plate. We will have centre aisle upstairs for storage plus space between trusses. The plan is to come off side with 26.5'x10' shed. This will hold hay and shavings. I have two other buildings for storage - which are filling fast.
See attached. The side roof will cover run-in for stalls. We will mirror this on opposite side fore storage on a slab. May start slab in fall - depending on budget. We are slightly under budget now...
Lloyd
/ Horse Barn Project #15
Very nice looking project. I assume that bunch of tubing will be for slab heating?
Bones1/Pineridge
The last posted drawings have changed a bit. We turned the roof 90 degrees so the gable is over the sliding doors. This will allow an upstairs door for moving things off the truck/trailer. Also, there will be less rain coming off roof in the direction of the doors (which evestrough would fix). Although I prefer the look of gables on the end (short side) I think this will work out better in the long run.
Pineridge. I decided to go with radiant heat in case there was a change of use down the road - my new shop or if we sell someone else will enjoy a new shop. It was easier and cheaper to do the tubing now than later. We zoned the tack room and outer area - two zones. I plan on playing with solar to see if I can heat the tack room only. If it doesn't work I will install a small electric hot water heater and do a loop in the tack room.
My wife is excited over her new barn. I offered to trade my workshop. It is slightly larger and a bit closer to the house. She would agree only on the condition I pay for the new one...I'll keep my old workshop/barn for now.
Thanks...
Lloyd
/ Horse Barn Project #17
I didn't check in for a couple of days but I see you have been busy. Can't wait to see more pictures.
DoubleG:
Been busy too - have not had a chance to file photos. Tomorrow is the last day for contractor. I booked him for two weeks - 100 hours. We are actually only into about 60 hours. We are 90% complete. I will be finishing inside stalls, doors etc.
Tomorrow we will finish stairs to second floor and finish gable ends with boards. I will be installing all the battens. Depending on where we land with the budget he may be back to install roof over stall run-ins.
Lloyd
Trusses and roof boarding-in.
Over roof boards we layed tar paper and installed metal roof over top.
Lloyd
Metal Roof:
Metal roof is on. In frame #5 you see the truss on the right side of sky light. We will be installing a 2x6 to mirror truss so it looks symetrical.
Lloyd
