Horn added to MT225e
   / Horn added to MT225e #1
rbstern
Platinum Member
GA
LS MT225E, Yanmar 2210
Finally got around to this. Pretty simple, about an hour, start to finish. I only have the one picture, showing where I mounted the horn. The M225e (and probably the XG3025) have an unused bracket on the front of the firewall, on the ignition switch side. Probably for a horn on a more deluxe model. Was able to put a 90 degree bend on the straight bracket of the motorcycle horn I bought on ebay. Tapped into the positive lead I had put in for my rear light, and there was a very convenient grounding nut just a few inches below the bracket. Simple, momentary rocker switch is also from ebay, has the horn symbol and "Horn" on it.
Here's the under the hood install:
   / Horn added to MT225e #2
Looks good.
My 5 year old nephew likes honking the horn on my XU6168CPS when he rides with me.
   / Horn added to MT225e #3
Nice install. Do you have a pic of the switch? That bracket is also present on the XG3025, so I 'll utilize that too. I haven't really looked for a switch yet.
   / Horn added to MT225e #5
   / Horn added to MT225e #6
I use the horn to honk at the dog when I see him doing something he shouldn't or to get him to start following me. Trained him to it.
Thats about the only time I use the horn.
(I was thinking while reading this "why would someone want a horn on a tractor?" Then I said to myself "well, I use the horn all the time!"
Just sharing my train of thought)
   / Horn added to MT225e #7
I think it might be handy if you had an emergency on the tractor or in the field. I frequently am without a phone or radio, the horn would be better than nothing.
I too need to beep at the dog ...
   / Horn added to MT225e #8
Exactly the reason that I was thinking. Easier to lay on the horn than try and get into the phone to dial then hope someone picks up right away!
My Yanmar 2210 has a horn and I use it either to rebuke the dog, or get the wife's attention. Or is it the other way around? I forget.
For the LS, seemed like a good way to fill an empty dash slot on the cheap with something functional.
   / Horn added to MT225e #10
Horn came on my XR. So far, just a quick blast for the dog, but I know wife will likely get one eventually.
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
John Deere Front Weight (A50515)
John Deere Front...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
