Hooks on a BH bucket... how many and where?
   / Hooks on a BH bucket... how many and where? #1
AKfish
Super Member
Alaska
JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Thinking about welding some hooks on my 20" backhoe bucket. Like to hear suggestions from anyone who has done that as well as ideas regarding placement and number of hooks used.
Thanks for any and all suggestions.
AKfish
Oh yah, pics would be great.... too!
   / Hooks on a BH bucket... how many and where? #2
A lot of folks place the hook on the back of the bucket.:D
   / Hooks on a BH bucket... how many and where? #3
Yes one hook on the back and as hight o the linkage as possible.
The idea is out of the way, yet allows the chain to run around the bucket, so when you curl it you'll gain some "lift'
   / Hooks on a BH bucket... how many and where? #4
According to the particular hoe it might be better to put it on the plate that connects the bucket links.
That would allow use (as a crane) without the bucket, providing better viz, more capacity by not having the bucket's weight and not having to weld a hook on every bucket.
Maybe not all hoes have a plate across the bucket links, in which case on the bucket may be the only option.
A loop is another option, then an anchor shackle to a chain hook; that would be a bit more flexible in that you could use rope through the loop for.... whatever,
   / Hooks on a BH bucket... how many and where? #5
I'd weld on a piece of plate on edge with a hole in it big enough for a clevis pin onthe back of the bucket. A hook will be more likely to get bent or broken and will wear faster than a plate. You can also use the plate/clevis with nylon straps for lifting, where a hook would damage the straps.
Sincerely, Dirt
   / Hooks on a BH bucket... how many and where? #6
I went a different route, IMO this is all you need and more.
   / Hooks on a BH bucket... how many and where? #7
JB4310, that's not a BH bucket.
   / Hooks on a BH bucket... how many and where? #8
Oops, didn't read the OP close enough, thought it was another loader bucket hook thread.
   / Hooks on a BH bucket... how many and where? #9
Would be good for grading tho if it were on the BH
202521 (A51406)
202521 (A51406)
11' CONTAINER (A54757)
25077 (A51694)
25077 (A51694)
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
