hooks for bucket
   / hooks for bucket
Hey guys, I asked it somewhere else too, but asking here, did any of you reinforce the top of the bucket when adding hooks? Would I need this for my little tractor?
I'm thinking 5/16 hooks on top, clevis ring under it on the other side. I guess no welding needed for that.
   / hooks for bucket #12
Ooh, that's a good point, I should have also mentioned I tend to use ratchet straps more than chains. So you mounted this to the sides (outside near top) of the bucket instead of on top?
I was not clear, but I did mount the hooks to the top of the bucket, and I also used a piece of 1/4" flat bar inside of the bucket so that the bucket is sandwiched beteen the hook and the flat bar.
I also bolted a HF 2" hitch on the top of the bucket in the center, use it mostly with an insert that has a shackle.
KC
   / hooks for bucket #13
My little Iseki only weighs about half a ton, so I figured by the time I got a quarter of a ton hanging off the bucket, the back wheels are almost going to off the ground, and I don`t want to be going there. Also I though of getting the lifting point, as low as possible. If the load is hanging from high up, and a wheel drops in a dip, theres a bigger chance of the weight pulling her over. As by my previous post, I went for the hole in the bucket, no reinforcement, and I`ve not had any problems with distortion.
   / hooks for bucket #14
For lifting capacity around 700 lbs, I just bolted some Cold Shuts (chain menders) to holes I found already there.
This is a 2005 photo - and they have held up well.
39929d1118694307-hooks-bucket-673366-img_3091bucket-logs-jpg
   / hooks for bucket #15
I rarely use anything other than 1/4" G70 chain any more. The WLL on it is 150% of what my loader will pick, and the breaking strength about 6X. Works in my 3/8" slots and is nice to handle too.
Good idea. :thumbsup:
   / hooks for bucket
   / hooks for bucket
Yeh, weight low is a good idea. I moved a few loads with it dangling below the bucket with strapped wrapped around the hitch receiver tube I have on the bucket, that's all I have now in terms of that. Another thing I was thinking, d-rings installed bottom inside corners of bucket, d-rings or hooks top of bucket on each side, I could see that being pretty handy.
   / hooks for bucket #18
IF you are lifting wheels off ground with 500 pounds in FEL you need rear ballast weight...
Dale
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
1997 Chevrolet C3500 Auto Crane Service Truck (A55852)
1997 Chevrolet...
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52707)
2017 CATERPILLAR...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
